![]() Drives: nissan 240sx Join Date: Nov 2008
Wheel fitment question
Hello, I am a fan of yaris and in the market to get one. but i was curious to know the widest wheel and lowest offset that i could use on a liftbacks? my preference is flushness rather than performance. and yes, the car would be one some type of coilovers.. so any ideas or pics??
there are members doing 17 x 7 without issues. I believe they run up to 205 width tires.
if you have too much positive offset on the wheel, you can always use 10mm or 15mm spacers to flush it out. Note that on the Yaris, the rear wheels appear to tuck more than the fronts with the same wheels.
sweet. thanks for the tip, but still would like to run something a bit wider if possible. does anyone run like 8 width with close to, say ~0 offset? anyone know if there are hub adapters to run 4x114.3 also?
My 17x7 38+ offsets were quite flush in the front. You could add a 10mm spacer in the back to even them out.
Contact 03Z33 or Walter on here. They have ran very flushed wheels/tires on their LB's.
![]() ![]() Drives: 08 silver streak mica LB Join Date: Oct 2008
i think +25 front +20 rear is what jeff is running.
who is jeff..? he's using +25 on an 8?
Jeff is 03Z33
This is what he shows in his garage: AME Shallen LX Diamond Cut 16x8 +25LO front 16x8 +18SLO rear with 195/45/16 Federal tires With 195 rubber, he is really stretched!
yeaaa ame makes sweet wheels. i like the vip look. i had some wheels that i had off my other car that i wanted to put on the yaris but wrong lug pattern =X they were about the sames sizes as his too. does anyone have any rubbing problems at all. ?
![]() ![]() ![]() ![]() Drives: 2008 Yaris HB Join Date: Oct 2008
I have 17x8 with +35 on mine and 205/45/17 tires and it is kinda stretched and rubs on bumps with the DF210s.I have learned to ignore it and drive slow on speed bumps.I wider tire would be torn up in days on my setup,as would my fenders.
The Vitz doesn't accommodate anything too radical very well... and remain a good daily driver.
Here's 17x7's and 205/40's on Tien modified suspension. FR, ET42//RR, ET35 It's a nice clean fitment with no worries. |
for the ppl that are rubbing, did you guys roll your fenders and still having rubbing issues? i think i'd still like to get wheels a bit wider...
Curious: What is the point in wider wheels when you're basically limited to 205 rubber?
#14 | |
crandall runs tenzoR rims that are 17x7 with a 35 offset and 215 tires he's slammed on tein basics but rubs on bumps or hard corners... i really dont think an 8" wide rim is a great idea on a yaris....esp w/ a 0 offset.....it looks like poop and does nothing for driveability
again, i'm not interested in driveability. i have a car that i track, so i'm just there for look.
and i never said i'm looking to run wider rubber. i'm looking for a better STRETCH. 195/45 is cool for an 8. and i look for lower offset on wheels because i like concave wheels or wheels with lip. is that a problem? |
#16 | |
well thanks for replying and stuff. i think jeff answered most of the questions. thanks.
| forged rims Vs. alloys | red-jdm | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 14 | 07-23-2007 09:30 PM |
| Wheel fitment? | PetersRedYaris | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 3 | 02-26-2007 01:18 PM |
| Tire Fitment question | Ryu | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 5 | 01-14-2007 02:47 AM |
| question, do I need my hubs protected by a wheel cover | foober | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 8 | 11-28-2006 01:25 PM |
| 20" wheel question | mikeukrainetz | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 7 | 10-26-2006 12:22 AM |
