Old 12-04-2008, 05:29 PM   #1
gboezio
gboezio's Avatar
Drives: Yaris 4dr 2008
gboezio is offline   Reply With Quote
Old 12-08-2008, 10:15 PM   #2
pinoypizzaboy
Drives: 08 toyota yaris LB
Originally Posted by gboezio View Post
im a noob at this.. but wich part do you attach the blow off valve? thru the intake piping or exhaust part?
pinoypizzaboy is offline   Reply With Quote
Old 12-12-2008, 11:58 AM   #3
4MPG
Drives: black 5spd hatch yaris
The BOV is placed after the turbo, in the compressed air (turbo to engine) section. The purpose of the BOV is to both help regulate maximum pressure in the intake (so it can be set to xxx max PSI) and to "blow off' whenever you lift off the throttle.
If you didn't have a blow off, or didn't have one properly sized for your application, on top of not being able to regulate the boost pressure you would get an effect called compressor surge. Basically when you snap closed the t/b blade (let off the gas) you have alot of pressure that is built up in the intake piping, and it has nowhere to go but back thru the turbo itself. This is generally pretty hard on the turbo, and can lead to bearing failure etc etc.
4MPG is offline   Reply With Quote
Old 12-17-2008, 12:24 PM   #4
Tamago
Tamago's Avatar
Drives: UZJ100
blow off valves do not regulate maximum air pressure
this is handled by a wastegate
and generally low boost applications don't require a BOV..
Under $2500 Tubo Kit Update 2 cdydjded Forced Induction Forum 72 11-02-2008 09:44 PM
$2500 Turbo Kit is back to life! bdc87 Forced Induction Forum 8 10-20-2008 09:46 AM
Under $2500 Turbo Kit w/Intercooler coming soon! cdydjded Forced Induction Forum 58 09-23-2007 02:02 PM
Under $2500 Tubo Kit Update cdydjded Forced Induction Forum 16 08-26-2007 11:05 PM
another small update on turbo kit. joey1320 Forced Induction Forum 6 08-23-2007 04:51 PM
