What?
The OE plugs are really GREAT plugs, and under "normal" driving they should last 100k miles. (so they say... at least 50k)
But, my experience with them after a fair amount of track use (lots of time at or near the redline, almost constant full-throttle acceleration for 20-40 minutes at a time) was that one of them started giving high-rpm misfires at about 18,000 miles. If you're just using the car for commuting and general driving, don't waste your time and money on spark plugs until/unless the computer throws a CEL for misfires. You're just throwing money away. And then, if you get 50k or more out of the OE plugs, the were obviously a good choice... replace with the same! If you do any sort of competition on a regular basis, you're better off switching to a standard (not iridium, not platinum, not unobtanium) NGK plug and just changing them every 10-20k. There is SO little performance to be gained by using uber-expensive plugs, it's just not worth it. |
| radio wire colors & alarm wire color reference guide | battleversiontc | In Car Entertainment + Electronics (audio / video / alarm) | 43 | 06-06-2023 02:12 PM |
| Viper Alarm Install | gwasabi | In Car Entertainment + Electronics (audio / video / alarm) | 28 | 08-11-2010 02:57 PM |
| Toyota AUX plug w/ aftermarket radio? | eight_heads | In Car Entertainment + Electronics (audio / video / alarm) | 20 | 09-07-2007 02:41 AM |
| Bujias?¿ Normales o otras? | Fer.pa | Central and South America | 12 | 07-13-2007 03:46 PM |
| Oil Drain Plug Size? | Nigal | DIY / Maintenance / Service | 4 | 05-31-2007 01:55 PM |
