Old 12-19-2008, 01:45 PM   #1
Tamago
Tamago's Avatar
Drives: UZJ100
Originally Posted by 09TRD View Post
That's a gravity cast wheel with very thin spokes.
That wheel wouldn't hold up on the roads here in the Northeast.
While it's heavier, the forged and polished Centerline is a vastly stronger, higher quality wheel.
ok, so you're set on the centerline.. let's drop it because we think you're wrong and you think we're wrong.. you're going to a wheel that's about the same weight as stock steelies
your offset will be fine..
you have the correct hub bore
stick to that low section width 205
i'm out..
Tamago is offline
Old 12-19-2008, 01:49 PM   #2
09TRD
Drives: 09 Yaris hatch, 09 Z51 'Vette
i'm out..
The wheel I'm talking about that weighs 15 pounds is a 17" diameter wheel.
They don't list the weight for the 15" version, though it would obviously be lighter:
http://centerlinewheels.com/wheels_d...d=36&sw_id=263 "Our 17" wheel weighs only 15 lbs!"
09TRD is offline
Slightly damaged wheel aucorium Wheels, Tires and Suspension Forum sponsored by The Tire Rack 5 12-06-2008 07:06 AM
SCION SPORT STEERING WHEEL, RED, XA AND XB, 03 TO 06 justoneyaris Items for Sale by private party 3 12-04-2008 06:30 PM
Wheel Advice caveatipse Cosmetic Modifications (Exterior/Interior) 8 09-19-2007 02:39 AM
Yaris wheel rate ratio (06+) ? dsc_pat Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 07-05-2007 05:43 PM
