Old 12-19-2008, 02:20 PM   #1
Loren
What?
Loren's Avatar
Drives: 2007 Yaris LB
14 pounds isn't "obscenely heavy" for a 15x7, but it's not exactly "light", either.
My 15x7 Falken Hanabi's weigh just a tick over 11 pounds each and cost about $89 each. THAT is light and cheap. But, not everyone likes the styling. My goals were "light and cheap", so I didn't care.
To answer your rubbing question: I'd stick with 195/55's. I've not had any rubbing with those. Had some with 215/50's (Toyo T1-R, which were actually closer to 205). And I'm on 15x7 with 41mm offset.
I also had rubbing on the upper fender liner under hard cornering with 195/55's on a 15x7 with 32mm offset. Definitely stick with offset in the 40-45mm range unless you value the bling of "flushness" more than not rubbing.
Loren is offline
Old 12-19-2008, 02:23 PM   #2
Russelt3hPirate
l33t3st Asshole
Russelt3hPirate's Avatar
Drives: MY07 Yaris Liftback
with the proper setup you can have bling flushness and no rubbing. :)
just takes a little extra work.
Russelt3hPirate is offline
Old 12-19-2008, 02:49 PM   #3
Tamago
Tamago's Avatar
Drives: UZJ100
hours of labor at the alignment rack
Tamago is offline
Old 12-19-2008, 02:34 PM   #4
09TRD
Drives: 09 Yaris hatch, 09 Z51 'Vette
Thanks for the advice.
Living here in the Northeast (pothole and frost-heave ravaged roads), I value strength.
I have yet to see an OEM aluminum wheel bend in this area, yet I've seen dozens of lightweight, cast aftermarket wheels bend.
Such is the cost of reducing weight by effectively removing material.
09TRD is offline
Old 12-19-2008, 02:41 PM   #5
Russelt3hPirate
l33t3st Asshole
I've seen an OEM aluminum wheel fall apart in NJ.
Old 12-19-2008, 02:42 PM   #6
09TRD
There are perhaps 5,000 of them for every one aftermarket wheel.
Try running a 10 pound aftermarket "racing wheel" in the NJ streets and see how long it lasts.
09TRD is offline
Old 12-19-2008, 02:45 PM   #7
Russelt3hPirate
l33t3st Asshole
I'm sure people do, in fact I know people running 18" variants of my wheel (not 10 lbs since it's a 18" wheel) but they aren't destroyed as you seem to be implying.
also, if a wheel is damaged by the state owned roads you can get the state to buy you a new wheel.
Seen it done numerous times when it is properly documented.
Old 12-19-2008, 02:51 PM   #8
09TRD
A wheel's strength is dictated primarily by it's wall thicknesses and it's material. (Spoke placement and the number of spokes is also a factor.)
A cast 15" wheel that weighs 10 pounds cannot, by definition, be a strong wheel in terms of impact loading (e.g. hitting a pothole).
Conversely, a forged (e.g. 6016-T6) 15" wheel that weighs 14 pounds will likely be VERY strong.
09TRD is offline
Old 12-19-2008, 02:53 PM   #9
Tamago
Tamago's Avatar
Drives: UZJ100
so you'd rather drive around on wheels that look like they should be on a 1977 ford falcon simply because they're FORGED???
why are you buying wheels in the first place?
Tamago is offline
Old 12-19-2008, 02:55 PM   #10
Tamago
Tamago's Avatar
Drives: UZJ100
or just improperly designed..
you should have a set of wheels made out of these:
you'll never bend them and they'll be plenty heavy enough for you
oh and cute typo on 6061-t6...
Tamago is offline
Slightly damaged wheel aucorium Wheels, Tires and Suspension Forum sponsored by The Tire Rack 5 12-06-2008 07:06 AM
SCION SPORT STEERING WHEEL, RED, XA AND XB, 03 TO 06 justoneyaris Items for Sale by private party 3 12-04-2008 06:30 PM
Wheel Advice caveatipse Cosmetic Modifications (Exterior/Interior) 8 09-19-2007 02:39 AM
Yaris wheel rate ratio (06+) ? dsc_pat Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 07-05-2007 05:43 PM
