Old 12-23-2008, 04:40 PM   #1
slvryaris
slvryaris's Avatar
Drives: 2007 Yaris Sedan S
The NGK plugs I got were the IFR5T11 which I am guessing is the IFR5A11 but a different number since it says they are the OEM replacement.
The only problem is the NGK plug is gapped at .032 sooooo I am guessing I need to widen the gap on these puppies. Some of the guys at Advanced said I shouldnt gap them since they are Iridium plugs, but the service manual says new plugs should be .039 to .043 in.
So in theory I should widen this gap?? Also why does on www.sparkplugs.com show that the OE gap is .032 but when you highlight the product to the right of it is a picture of the plug and the specs on it and then at the bottom of the specs it says .044" (1.1mm) Gap
Extreme Long Life Laser Iridium Plug, 14mm Thread, 19mm (3/4") Reach, 5/8" (16mm) Hex Size, Gasket Seat, Resistor, Solid Terminal, Projected Tip, Iridium Tipped Fine Wire Center Electrode with Platinum Tipped Ground Electrode, .044" (1.1mm) Gap
slvryaris is offline   Reply With Quote
radio wire colors & alarm wire color reference guide battleversiontc In Car Entertainment + Electronics (audio / video / alarm) 43 06-06-2023 02:12 PM
Viper Alarm Install gwasabi In Car Entertainment + Electronics (audio / video / alarm) 28 08-11-2010 02:57 PM
Toyota AUX plug w/ aftermarket radio? eight_heads In Car Entertainment + Electronics (audio / video / alarm) 20 09-07-2007 02:41 AM
Bujias?¿ Normales o otras? Fer.pa Central and South America 12 07-13-2007 03:46 PM
Oil Drain Plug Size? Nigal DIY / Maintenance / Service 4 05-31-2007 01:55 PM
