Old 10-20-2009, 12:11 PM   #1
charleschia1986
charleschia1986's Avatar
Drives: Yaris RUSH HatchBack
The connector (4K) on the upper left in this picture, is the feed to the map and dome lights. White with a black stripe ground, Pink is the "door open" switched ground, and blue is 12V fed from the DOME fuse.
hi there,
may i know where can i find this stuff?
regards,
Charles
charleschia1986 is offline   Reply With Quote
Old 10-20-2009, 01:26 PM   #2
Originally Posted by charleschia1986 View Post
hi there,
regards,
Charles
If you mean where are the wires in the picture, they are right behind the pull out pocket on the bottom left of the dash.
Old 10-20-2009, 09:39 PM   #3
charleschia1986
hi there,
so did ya mean it is located under the driver seat or passenger seat? because my driver seat is on right hand side.
regards,
Charles.
Old 11-24-2009, 01:04 AM   #4
charleschia1986
Hihi, I already tested the wires tat u mentioned in the picture.. The blue wire does give constant 12v and the pink wire should turn on the lights with the door right?
I already tested the pink wire by multimeter and it will only give 12v when the door is closed.
So may I know what can I do in order to get 12v out when the door is open because I want my led to be on only when the door is open...
Thanks...
Old 11-24-2009, 06:56 AM   #5
Thanks...
Use the pink as ground and the blue as your +12V.
Old 11-24-2009, 11:55 AM   #6
charleschia1986
thanks a lot...
i tried and it WORKS.....
thank scott
Old 06-09-2010, 10:47 AM   #7
jonimac
jonimac's Avatar
Drives: Yaris Sedan 2010
Send a message via Yahoo to jonimac
Hi to all... just a noob here in M.E., just wondering if I tap the leads (+,-) of an LED light to the pink n blue from that pic above, will the new led light acts the same as the dome light? will the new led light dim to off as well upon turning off the ignition? Or just turns on when the doors were open? Sorry to much question. Need help where I can tap my led lights so that it behaves the same like the dome light, using its switch also to turn on my led lights underneath. Thanks so much. -jon
jonimac is offline   Reply With Quote
Old 06-09-2010, 11:02 AM   #8
If you tap the pink and blue, the LEDs will behave the same as them dome lights, provided that you leave the dome light switch in the "Door" position. If you manually switch the dome to "On", with the doors closed, the LEDs won't light up with the dome.
Old 06-09-2010, 04:56 PM   #9
jonimac
jonimac's Avatar
Thanks CTScott... got the idea!
Old 03-19-2011, 07:44 AM   #10
iicaie
Drives: Vios E
Hi, how do you suggest wiring LEDs so that they behave exactly like the dome light does? ie. turn on when doors open, switch to ON - light up with dome light. thanks
iicaie is offline   Reply With Quote
Old 08-18-2009, 11:39 AM   #11
47_MasoN_47
What I thought I'd do was
47_MasoN_47's Avatar
Drives: 09 Yaris Sedan
Alright, so if I'm thinking correctly I should connect the + lead from the lights to the blue wire, and the ground to the pink one?
Old 08-18-2009, 12:14 PM   #12
Correct.
Old 10-22-2009, 06:15 PM   #13
Sora65
Drives: Beautiful :)
Correct.
Wait so i can put for than 1 wire in that hole?
Or should i use on of those clip things to wire?
i have no idea about wiring stuff :(
but i really wanna get some lights for the foot area..
Sora65 is offline   Reply With Quote
Old 10-22-2009, 08:32 PM   #14
Use the clip things (tap splices). Just sticking the wire in along side of the existing wire does not make a reliable connection.
Old 08-18-2009, 12:38 PM   #15
47_MasoN_47
Awesome, thanks!
Old 08-21-2009, 07:33 PM   #16
Liu997
Drives: 2008 Red Yaris LB
So the yellow 12volt wire described in the first post is constant even when the car is off?
Liu997 is offline   Reply With Quote
Old 08-21-2009, 10:03 PM   #17
Yes
Old 09-19-2009, 05:56 AM   #18
kompressorgpl
Drives: yaris 1.0 vvt-i
Hello! I have an alarm to put on my Yaris (from 2002). Where i can find a diagram of the car with that?
kompressorgpl is offline   Reply With Quote
2012 Yaris at SEMA Jason@SportsCar Third Gen Yaris General Discussion 5 09-23-2013 03:55 AM
New Yaris race car Jason@SportsCar Tracking, Racing, Auto-X Forum 83 11-01-2012 02:32 PM
