Old 12-30-2008, 07:44 AM   #1
xpeteyjtx
Drives: 07 BB Yaris
To answer your question 12.mm (1/2") replaced my drain plug
with a alloy one with a magnet in it
you are the best
now I need to find a 13-14mm (.562") ID aluminum washer
so what exactly is the thread on the drain bolt?
xpeteyjtx is offline   Reply With Quote
Old 12-30-2008, 12:37 PM   #2
TheSilkySmooth
TheSilkySmooth's Avatar
Drives: 08 3DR 5M Bayou Blue; 09 Fos
Originally Posted by xpeteyjtx View Post
you are the best
The TOY washer for the older 2azFE is better being rubberized and good for 4-6 uses if you dont WAIL on it torques wize. - and only a masochist would pay a buck for a 2 cent washer. I would not use Al here though due to possibility it would corrode OFFF the car in the winter, maybe instead a solder tinned Cu washer. That being said I DID spend a buck on this 5c washer at the dealer 'cause I was TOO LAZY to walk into the hardware store and look for copper washers ... So I am Lazy but NOT a masochist
bro for sonja
TheSilkySmooth is offline   Reply With Quote
Old 12-30-2008, 12:41 PM   #3
TheSilkySmooth
you are the best
On a related subject, Though they are good filters DONT use thepurolator filter 'cause the nipple on the filter mount is too short and you will engage less than 2 threads - which is recipe for disaster.
Any one else have short nipple or is it just our car(08 3dr 1.5L 5 spd)
hey xpete, I'm in Wilmington, MA
Old 12-30-2008, 01:07 PM   #4
xpeteyjtx
Drives: 07 BB Yaris
I did not know that about the purolators. the toyota denso filters spin quite a few times before the rubber is seated.
I'm on the other side of the pike.
Old 12-30-2008, 01:27 PM   #5
TheSilkySmooth
Yes the Densos spin a few times, you prob noticed how the threaded hole is pretty much flush to the top edge.
My cube mate live in Athol.
-the bro
DIY: CHANGE MANUAL TRANNY OIL ttufrosty DIY / Maintenance / Service 157 09-07-2018 01:43 PM
Magnetic Oil Drain Plug PetersRedYaris DIY / Maintenance / Service 13 11-16-2010 06:41 PM
Magnetic drain plug proof ! usmc DIY / Maintenance / Service 26 11-17-2008 06:55 PM
Oil Drain Plug Size? Nigal DIY / Maintenance / Service 4 05-31-2007 01:55 PM
Magnetic Drain Plug Source? blacksan DIY / Maintenance / Service 9 05-11-2007 08:01 AM
