Old 10-23-2008, 05:14 PM   #1
usmc
Drives: 08 liftback
Magnetic drain plug proof !
08' Liftback. 4500 miles on the oil change. Mobil 1 syn EP. 15000 miles on the odometer. Used with a mobil 1 oil filter.
usmc is offline   Reply With Quote
Old 10-23-2008, 05:19 PM   #2
aca72
aca72's Avatar
Drives: '07 Yaris S Sedan M5
It works!
aca72 is offline   Reply With Quote
Old 10-23-2008, 05:25 PM   #3
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
Exactly... I don't understand why some people are so adement about the filter magnet. This is cheaper, as effective, you can see the results, and diagnose major problems before they occur.
For $15, why not install one?
Old 10-23-2008, 06:12 PM   #4
usmc
Drives: 08 liftback
....and after
After cleaning.
Old 10-24-2008, 09:06 AM   #5
macro mode... enable macro mode.. ^^
Old 10-24-2008, 09:56 AM   #6
SilverGlow
Drives: 2007 Yaris Hatchback
Why are you using Mobil1 EP on an engine still under warranty? Even Mobil1 states on their site not to go the full 15,000 miles if the car is still under warranty....using EP is a waste of money if the engine is still under warranty...I would not go more then 5,000 miles between changes for warranty reasons...switch to Mobil1 0w-20 or 5w-20 and go no longer then 5,000...just my suggestion....
SilverGlow is offline   Reply With Quote
Old 10-24-2008, 10:06 AM   #7
bearda
bearda's Avatar
Drives: 2006 Mazda3 Sedan
Well, admittedly he did say it was 4500 on the oil change, not 15000.
Is it normal for the magnet to be offset like that?
bearda is offline   Reply With Quote
Old 10-24-2008, 10:15 AM   #8
nsmitchell
nsmitchell's Avatar
Oil filter magnets are FREE! Take them out of hard drives. Find a computer geek and ask them for a magnet or 2. All geeks have hard drive magnets laying around. hehe (at least all the ones I know, including me)
They are very powerful and they just snap right on the your filter. Use as many as you like.
Get YarAss in gear!
RIP - Casey Tatum
Old 10-24-2008, 10:15 AM   #9
nsmitchell
nsmitchell's Avatar
That is a lot of metal shavings for one oil change. Was it more like a metallic paste or were there any hard pieces attached to the magnet?
Get YarAss in gear!
RIP - Casey Tatum
Old 10-25-2008, 11:14 PM   #10
auxmike
auxmike's Avatar
That magnet is way off center on the plug. Is it a DIY project?
Got mine on Ebay for $10 myself.
I'll be sure to post a pic when I do my next OC.
Old 10-25-2008, 11:37 PM   #11
msfire671
ONE LOVE...YARiS LOVE!!!
msfire671's Avatar
Drives: Toyota Yaris
Send a message via MSN to msfire671 Send a message via Yahoo to msfire671
any for a 2008 yaris sedan?
msfire671 is offline   Reply With Quote
Old 10-26-2008, 11:07 AM   #12
TheSilkySmooth
TheSilkySmooth's Avatar
Why not let the oil filter capure the particles - it is there for this reason. If you go around a tight corner at high rpm you could make a tornado in your oil pan and this debris would get swept off and start circulating - our timing chain can pump this stuff up top - another problem chain vs timing belt. Is you chain noisy whirrring noise?? this is a lot of debris.
Old 10-26-2008, 11:10 AM   #13
TheSilkySmooth
My brother the bike mechanic says metal parts would come from rings, bumpstick and crankshaft. I like the bumpstick and the crank:0
Old 10-26-2008, 11:12 AM   #14
TheSilkySmooth
He say chain and sprockets too
Old 10-26-2008, 11:13 AM   #15
TheSilkySmooth
I did not type this my Papa did. Go AWAY!
Old 10-26-2008, 11:14 AM   #16
TheSilkySmooth
No Peace in this house!
Old 10-26-2008, 06:56 PM   #17
PetersRedYaris
So anyway... I don't know any computer geeks.
Old 10-26-2008, 07:04 PM   #18
tk-421
tk-421's Avatar
Drives: 5D-07-LB
I am interested in this idea. I have a few broken hard drives that I've been collecting over the years...
How many magnets would be enough for this?
DIY: CHANGE MANUAL TRANNY OIL ttufrosty DIY / Maintenance / Service 157 09-07-2018 01:43 PM
Magnetic Oil Drain Plug PetersRedYaris DIY / Maintenance / Service 13 11-16-2010 06:41 PM
Oil Drain Plug Size? Nigal DIY / Maintenance / Service 4 05-31-2007 01:55 PM
Who Makes Magnetic Transmission Plug? blacksan DIY / Maintenance / Service 5 05-22-2007 10:15 AM
Magnetic Drain Plug Source? blacksan DIY / Maintenance / Service 9 05-11-2007 08:01 AM
