#1 | |
Actually all the dealers in my area will put N2 in your tires for free...so I guess that blows away your theory. Oh and BTW, go here for the truth about N2.... http://www.getnitrogen.org/pdf/graham.pdf |
#2 | |
Parallel Parking Pro
Leong's NCP91 Toyota Yaris E Hankook V12 Evo 195/55/15 on Buddy Club P1 replicas 15x7 ET +38 Stebel horns, Philips Silvervision turn indicator bulbs TTE Lowering Springs, Camber bolts TRD Blue brake pads Fujitsubo Super Wagolis axleback exhaust DC Sports header |
#3 | |
Joey
Drives: '14 Scion xD 5-speed Join Date: Oct 2008
Formerly owned Met-Met. '07 Yaris LB 5-speed. A forum post should be like a skirt: Long enough to cover the subject but short enough to keep things interesting. "I don't have an anger problem. I have an idiot problem." -Hank Hill |
#4 | |
![]() ![]() ![]() ![]() ![]() Drives: . Join Date: Feb 2007
#5 | |
The 4 highest constituents of air are: Nitrogen N2 78.084% Oxygen O2 20.947% Argon Ar 0.934% Carbon Dioxide CO2 0.033% That, by my reckoning, makes 99.998% or so. I think we can ignore the rest, as they are all in the part/million area. If only 20% is oxygen, and the nitrogen doesn't permeate out, then at the first refill with air, there should be only 4% oxygen left. When that has leaked out and been replaced, then there should only be 0.8%, and so on. So - I am still amazed at the claims,m and will HAVE to try for myself. As far as it not expanding with heat - THAT is BS. Pure BS. IMNSFHO |
#6 | |
The Get Nitrogen Institute claims to be a nonprofit organization, but it is clearly a marketing ploy by companies that sell nitrogen. Look at their web site and the list of "sponsors"...what do you think is their agenda? Heck, it is like the beef industry telling us the benefits of eating steak...they sure has hell aren't going to tell you about the down side to it! It is pure propaganda, and I recently took a grad school course in it so to the trained eye it is very obvious. The Get Nitrogen Institute claims that by using nitrogen would save 3,716,692,884.802 gallons of gas per year (from their web site), but they fail to inform you that the same could be achieved by convincing people to regularly checking the air pressure in their tires! That, my friends, is propaganda...the twisting of the truth to convince people of one thing; when different conclusions are also available but not addressed. Air in tires has worked for over 100 years and whereas it may not keep its pressure as well as nitrogen, it is readily available and free for the most part (I have my own compressor, so filling up my tires is a snap!). The bottom line is if you want to use nitrogen in your tires, that's great and God bless ya! But the benefits do not exceed those of just using air by enough to make me want to switch. Cheers! M2 |
| DIY - Bypassing Tire Pressure Warning System (TPWS / TPMS) | CTScott | DIY / Maintenance / Service | 221 | 07-16-2025 01:20 AM |
| Tire Pressure Max | deebrown | DIY / Maintenance / Service | 82 | 08-10-2007 09:44 AM |
| Tire Pressure and Gas Economy | KittenRD | General Yaris / Vitz Discussion | 11 | 01-25-2007 10:54 PM |
| Tire Pressure | slvryaris | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 8 | 11-05-2006 12:37 PM |
| The Tire inflation debate... | Tankota | General Yaris / Vitz Discussion | 20 | 06-01-2006 07:09 PM |
