Old 01-26-2009, 04:02 PM   #37
SailDesign
Drives: .
Originally Posted by gid View Post
is it a bird ? A plane ? Why no , it's SUPER YARIS !!! Thanks to helium filled tires .
Methinks gid is high already - doesn't NEED helium-filled tires...
Old 01-26-2009, 04:37 PM   #38
ddongbap
I filled my tires with that fixaflat stuff.
Even tho my tires wern't flat.
Old 01-26-2009, 04:39 PM   #39
gid
yup , O.D.'d on Life Itself . Great BLUE OYSTER CULT song , www.youtube.com/watch?v=jAT5ewOfwEI . Take a listen .
Old 01-26-2009, 08:08 PM   #40
b_hickman11
Drives: 08 Sedan
Krayzee - this is pure, unadulterated BS. Nothing personal, this is what everyone is saying, after all. However, if you look up "Boyle's Law", you'll note that ALL gases expand and contract with the heat. It is part of being a gas.
What nitrogen does that is better than plain ol' air is that it doesn't degrade the tires, due to a lack of oxygen. However, as anyone with winter and summer tires hanging in the garage 6 months of the year will know, the tires them selves wear out before the insides get brittle due to atmospheric problems.
Nitrogen does NOT leak out more slowly than air. Air is 80-some percent nitrogen and therefore should behave pretty much exactly the same. Other "parts" of air have larger molecules even than nitrogen, so would "leak" even slower.
Let's all try t okeep up here, OK? Nitrogen is simply a great way to make money from people who like fads.
Actually all the dealers in my area will put N2 in your tires for free...so I guess that blows away your theory.
Oh and BTW, go here for the truth about N2....
http://www.getnitrogen.org/pdf/graham.pdf
Old 01-27-2009, 12:07 AM   #41
Kioshi
Heart Up! Vitz
Kioshi's Avatar
Drives: トヨタ Vitz
I guess I'll have to try nitrogen now.
Let me know your experience w/ it.
Old 01-27-2009, 02:59 AM   #42
cleong
Parallel Parking Pro
cleong's Avatar
Drives: Yaris 1.5 Manual
I wouldn't pay extra to have pure nitrogen put into my car's tires though.
Leong's NCP91 Toyota Yaris E
TRD Blue brake pads
DC Sports header
Old 01-27-2009, 03:54 AM   #43
SilverBack
Joey
SilverBack's Avatar
Drives: '14 Scion xD 5-speed
Let's all try t okeep up here, OK? Nitrogen is simply a great way to make money from people who like fads.[/url]
Sail, have you tried the nitrogen yet? Still waiting for you to prove me wrong, my friend
Old 01-27-2009, 08:09 AM   #44
SailDesign
Drives: .
Will check out the link - but I'll let my theory be blown away (by nitrogen, presumably?) for now. Can't say I didn't try....
Old 01-27-2009, 08:16 AM   #45
SailDesign
Drives: .
Well, that tells it like it is about nitrogen leaking, but it compares it to oxygen (only about 20% of "air") rather than to air itself.
The 4 highest constituents of air are:
Nitrogen N2 78.084%
Oxygen O2 20.947%
Argon Ar 0.934%
Carbon Dioxide CO2 0.033%
That, by my reckoning, makes 99.998% or so. I think we can ignore the rest, as they are all in the part/million area.
If only 20% is oxygen, and the nitrogen doesn't permeate out, then at the first refill with air, there should be only 4% oxygen left. When that has leaked out and been replaced, then there should only be 0.8%, and so on.
So - I am still amazed at the claims,m and will HAVE to try for myself.
As far as it not expanding with heat - THAT is BS. Pure BS. IMNSFHO
Old 01-27-2009, 08:50 AM   #46
MadMax
MadMax's Avatar
I have a hard time believing any documents that come from an organization whose mission is to "provide consumers, over-the-road truckers, fleet managers and others about the benefits of using nitrogen in tires."
The Get Nitrogen Institute claims to be a nonprofit organization, but it is clearly a marketing ploy by companies that sell nitrogen. Look at their web site and the list of "sponsors"...what do you think is their agenda? Heck, it is like the beef industry telling us the benefits of eating steak...they sure has hell aren't going to tell you about the down side to it! It is pure propaganda, and I recently took a grad school course in it so to the trained eye it is very obvious. The Get Nitrogen Institute claims that by using nitrogen would save 3,716,692,884.802 gallons of gas per year (from their web site), but they fail to inform you that the same could be achieved by convincing people to regularly checking the air pressure in their tires! That, my friends, is propaganda...the twisting of the truth to convince people of one thing; when different conclusions are also available but not addressed.
Air in tires has worked for over 100 years and whereas it may not keep its pressure as well as nitrogen, it is readily available and free for the most part (I have my own compressor, so filling up my tires is a snap!).
The bottom line is if you want to use nitrogen in your tires, that's great and God bless ya! But the benefits do not exceed those of just using air by enough to make me want to switch.
Cheers! M2
Old 01-27-2009, 10:17 AM   #47
TgrChica7
Need to sell my Yaris :(
TgrChica7's Avatar
Drives: 07 Yaris S
I work in a tire and automotive place and we have all converted to Nitrogen, i've definatley noticed a difference. I don't pay for it either. But normally its $2 per tire and then free for the life of the tire after that. Much better ride than regular air and I won't have to worry about checking the pressure as often. As far as what pressure to keep your tires at.... you should keep your pressure at what the vehicle calls for (the little placard on the inside of the door). Higher pressures could result in a faster and worse blow out if you would happen to hit a pot hole, not saying that lower pressures couldn't do the same but it will be worse with higher. Seen it happen... Tires have a max load on them, but that doesn't mean they should be put up to that pressure. Also causes abnormal wear on the tires if you keep them higher or lower for too long, then you're looking at new tires. BUT in the end it really what you feel you want to keep them at...
DIY - Bypassing Tire Pressure Warning System (TPWS / TPMS) CTScott DIY / Maintenance / Service 221 07-16-2025 01:20 AM
Tire Pressure Max deebrown DIY / Maintenance / Service 82 08-10-2007 09:44 AM
Tire Pressure and Gas Economy KittenRD General Yaris / Vitz Discussion 11 01-25-2007 10:54 PM
Tire Pressure slvryaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 8 11-05-2006 12:37 PM
