Originally Posted by manborn
thanks for the pictures!
i have the correct connections for the above. troubleshooted with ultrastart support in CA, guy found i had my start wire for the remote start in the wrong harness slot, moved it. supplying 12v+ 3 times activated starter. then just had to take that wire an applied it to my door unlock which was on the most bottom harness in the kick panel fat light blue(12+). tested unlock switch 3 times, started. tested unlock in remote 3 times, started.
i thought i connected the brake light so if i step on it when the auto started it would turn off but no. is the trunk wire same as the hood wire? seems that there is no sensor when the hood is open but there is for the trunk. i might have to use the autostart's hood toggle switch which had a perfect mounting hole above the battery that can get hit when the hood is closed. will post pics later.
Trunk and hood are separate. The hood switch is only present when the factory alarm is installed, otherwise you have to add the pin switch included with the remote starter.
The brake switch is either of the green wires on the connector just above the brake pedal. You can't use the brake lights, as the remote starters want a ground on brake.
