#31 |
are u still 34/39?
Drives: flint mica yaris s sedan Join Date: Sep 2006
brake switch was easy but odd, i had a choice of blue or green(what happened to light green?)going to the same socket. tapped green, now brake turns the engine off if key is not in prior.
![]() i'm now convinced that all yaris are not made equal. that some unlock wires are green and others (like mine) is blue-green/light blue, whatever. who knows what color my lock wire is, will soon find out. took a look at 4a and it's buried. cut zip tie and thought that was it but 4a is covered by a release lock, when unlock it disengages the harness. even if i had it removed, just no room to move unless you can fit both your hands inside the drivers left compartment below the cup holder. i think i will have to give the parking lights up now to locate those rs3200 rearm/disarm wires which are supposed to be 500ma outputs - low current and are designed to activate relays. Last edited by manborn; 03-12-2009 at 10:47 AM. |
| Northeast DIY Remote Start / Keyless Entry Workshop - Sunday, October 26 | CTScott | General Yaris / Vitz Discussion | 51 | 11-10-2012 01:32 PM |
| remote starter, instaled but cant get tach sig? | karl53913 | DIY / Maintenance / Service | 8 | 11-26-2008 10:40 AM |
| Remote Car Starter | KittenRD | Fuel Economy Forum | 6 | 11-08-2008 11:53 AM |
| starter kill & horn help | spechuy | DIY / Maintenance / Service | 0 | 10-20-2008 01:30 PM |
