Old 03-12-2009, 12:13 AM   #1
manborn
are u still 34/39?
manborn's Avatar
Drives: flint mica yaris s sedan
brake switch was easy but odd, i had a choice of blue or green(what happened to light green?)going to the same socket. tapped green, now brake turns the engine off if key is not in prior.
i'm now convinced that all yaris are not made equal. that some unlock wires are green and others (like mine) is blue-green/light blue, whatever. who knows what color my lock wire is, will soon find out.
took a look at 4a and it's buried. cut zip tie and thought that was it but 4a is covered by a release lock, when unlock it disengages the harness. even if i had it removed, just no room to move unless you can fit both your hands inside the drivers left compartment below the cup holder. i think i will have to give the parking lights up
now to locate those rs3200 rearm/disarm wires which are supposed to be 500ma outputs - low current and are designed to activate relays.
manborn is offline   Reply With Quote
Old 03-12-2009, 08:12 AM   #2
now to locate those rs3200 rearm/disarm wires which are supposed to be 500ma outputs - low current and are designed to activate relays. will post pics.
Mine wanted a parking light + as well. After struggling with the space to work and tightness of the wires at 4A, I decided to just invert my output with a relay and use the easily accessible parking light - at the headlight switch connector.
With the lock and unlock wires, 07 vs 08-09 have different colors in the kick panel. Position is the same, but wire colors are different.
Old 03-12-2009, 09:07 AM   #3
manborn
are u still 34/39?
manborn's Avatar
im 07, just looking for those rs3200 rearm/disarm wires now. i might have to trace the beep noise from when i press the keyless remote and see where it leads me. thank you.
Old 03-12-2009, 10:13 AM   #4
I have the manuals and EWD's for the 2006-2008 RS3200. PM me an email address and I'll shoot them to you...
Northeast DIY Remote Start / Keyless Entry Workshop - Sunday, October 26 CTScott General Yaris / Vitz Discussion 51 11-10-2012 01:32 PM
remote starter, instaled but cant get tach sig? karl53913 DIY / Maintenance / Service 8 11-26-2008 10:40 AM
Remote Car Starter KittenRD Fuel Economy Forum 6 11-08-2008 11:53 AM
starter kill & horn help spechuy DIY / Maintenance / Service 0 10-20-2008 01:30 PM
