Old 03-13-2009, 11:10 AM   #1
Yawesh
Yawesh's Avatar
Drives: 08 sedan at
Should i go get a "Free" wheel alignment
so i see that wheel alignments are covered via warranty for the first year. My vehicle warranty 'started' in july.
Thinking about going to the dealer and complain my car can't drive straight on the highway, so i can bag a 'free' alignment
what u guys think?
Yawesh is offline   Reply With Quote
Old 03-13-2009, 11:24 AM   #2
hatchbackkid82
Drives: .
do it
Old 03-13-2009, 01:16 PM   #3
MUSKOKA800
MUSKOKA800's Avatar
Personally, unless you need an alignment, I'd stay as far from the stealership as possible.
Perhaps is just bad luck, but strange, and often expensive things always happen to my vehicles shortly after visiting a shop. There's no dought that once they have your car as hostege the $ signs start flashing in their eyes. This is why dealerships often offer dirt cheap oil changes. "Oh, by the way sir, we noticed that XXXX also needs attention. We should do that now as well".
Old 09-14-2009, 09:44 AM   #4
Phaeton
Phaeton's Avatar
Drives: Blazing Blue Liftback
My dealer is a rare exception from the norm. They haven't found or recommended any services that I didn't need. So far I've only had my oil changed and had the tires rotated. I've got 64,000 miles on my car.
Old 03-13-2009, 02:43 PM   #5
nemelek
DWEED
nemelek's Avatar
If you put a value on your time, just to get a wheel alignment because it's free will cost you hours of your life that you will never get back. If you were going to the dealership for other work you might want it done.
Old 03-13-2009, 03:07 PM   #6
SilverBack
Joey
SilverBack's Avatar
Drives: '14 Scion xD 5-speed
+1. If you're gonna be stuck there all day for other services, then you might as well get the free alignment. Otherwise, don't bother
Old 03-13-2009, 03:13 PM   #7
BailOut
Steals terrorist's lunch
BailOut's Avatar
I subscribe to the "If it isn't broke don't fix it." philosophy.
- Brian
Share the Road
Old 03-13-2009, 04:35 PM   #8
tomato
tomato's Avatar
+1
Old 03-13-2009, 06:24 PM   #9
Yawesh
Yawesh's Avatar
Drives: 08 sedan at
actually it is beyond awful on the highway....maybe it's time to rotate my tires? it's 8000 miles...it hasn't been rotated yet i believe(bought it at 5k)
Old 03-14-2009, 04:51 AM   #10
RogueYaris
Drives: 2015 Abs Red
+2. That and really, it takes away from services that really do need to be done.
Do you think that you actually need it?
RogueYaris is offline   Reply With Quote
Old 09-13-2009, 10:38 PM   #11
tomato
tomato's Avatar
+1
Old 09-13-2009, 10:40 PM   #12
Tamago
Tamago's Avatar
Drives: UZJ100
+1
neither of you autocross huh.. lol
Old 09-13-2009, 11:06 PM   #13
2006fronty
2006fronty's Avatar
Drives: 2010 Mazda3 iTouring
what did they do to the rear of your car on this 4 wheel alignment? ;)
I'm guessing they didn't do a da#m thing in the rear lol.
Old 03-13-2009, 03:46 PM   #14
SeaYa
Is about to 'SeaYa' later
SeaYa's Avatar
Drives: 08 MT Sedan
what u guys think?
Only if your car is actually hard to keep straight on the highway. Otherwise, save it just in case you do screw up your alignment in the next few months.
SeaYa is offline   Reply With Quote
Old 03-13-2009, 03:51 PM   #15
BLAZINBLUEVITZ
BLAZINBLUEVITZ's Avatar
Drives: 2007 YARIS 3DOOR
good tech will take car out on highway to confirm your complaint......
Old 03-13-2009, 04:17 PM   #16
Tamago
Tamago's Avatar
Drives: UZJ100
take some camber bolts when you go and turn your "free" alignment into a "custom" alignment
i say do it.
Old 03-13-2009, 05:23 PM   #17
Loren
What?
Loren's Avatar
Drives: 2007 Yaris LB
They'll just put it on the rack, see that it's within the (wide) factory tolerances and say it's fine. Not worth your time.
Old 03-14-2009, 09:52 AM   #18
Tamago
Tamago's Avatar
Drives: UZJ100
and this is why you wander back and make friends with the alignment tech, ask him if he can install your camber bolts, and get you the alignment you want.
a custom alignment doesn't take any more time than a regular alignment, really.
Steering Wheel Issue. Twistoffate0817 General Yaris / Vitz Discussion 8 01-31-2009 07:38 PM
Slightly damaged wheel aucorium Wheels, Tires and Suspension Forum sponsored by The Tire Rack 5 12-06-2008 07:06 AM
Yaris wheel rate ratio (06+) ? dsc_pat Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 07-05-2007 05:43 PM
Wheel Alignment Data Asif Kazani Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 01-22-2007 12:48 AM
