My soldering abilities are good enough to connect wires, but not good enough to populate a board. What would one cost assembled (I can wire the thing into the car)?
MetalShark
Drives: 2008 Yaris LB Join Date: Oct 2008
As beta test consumer I might be able to cost it low. The biggest problem is the BS2 chip costs $50. I need to re-prototype this project using the new Parallax Propeller chip since they just dropped the cost to $7.95. The propeller has so many beans you could put the entire Toyota engine management code on it if they would let you have a copy. The parts at-cost is roughly $80 without display LED's AND you'd want me to load the program into the BS2 EEPROM for you too. It is a neat integrated prototype though and cops always ask what it is because when the key is on and the motor dead the display chases left to right and right to left like the original KIT. The cops have to know its not an illegal mobile police scanner. They give it a thumbs up. In a Propeller version I would integrate the dash dimmer control into the unit.
Absolutely red, Drawtite hitch, CAI, Insulated Header, Amsoil 5w-30, Mag-drain plug, Red-Line MT-90 tranny oil, Scotch-Guard, Window Tint, Dash rug, Custom short throw shifter, Lowered OEM arm rest, Super-Turbo muffler/w chrome slash cut tip., TRD rear sway bar, sticky pads, front shock tower bar, RS grill badge, VVT-i emblems, Second tire set from Tirerack.com, DISABLED DAY TIME RUNNING LIGHTS, platform- style locking custom bike rack. 86K miles so far. 5 years use now on ceramic wrapped insulated stainless-steel header. Last edited by metalshark; 04-02-2009 at 05:31 PM. Reason: Inclusion of ball-park costing SWAG. |
#3 | |
For example the PIC16F57 is $1.55 and has 20 I/O Pins and runs at up to 20mHz. If you're not comfortable with C or assembly programming, there is even a basic compiler for the PICs. http://search.digikey.com/scripts/Dk...IC16F57-I/P-ND |
![]() ![]() ![]() Drives: Polar White Yaris HB Join Date: Dec 2008
This project has tons of potential and looks great! When will it be avaliable for the rest of us willing to pay?????
#5 | |
MetalShark
Absolutely red, Drawtite hitch, CAI, Insulated Header, Amsoil 5w-30, Mag-drain plug, Red-Line MT-90 tranny oil, Scotch-Guard, Window Tint, Dash rug, Custom short throw shifter, Lowered OEM arm rest, Super-Turbo muffler/w chrome slash cut tip., TRD rear sway bar, sticky pads, front shock tower bar, RS grill badge, VVT-i emblems, Second tire set from Tirerack.com, DISABLED DAY TIME RUNNING LIGHTS, platform- style locking custom bike rack. 86K miles so far. 5 years use now on ceramic wrapped insulated stainless-steel header. |
#6 | |||
now in HD
#7 | |
MetalShark
#8 | |
MetalShark
#9 | |
MetalShark
Microchip
#10 | |
$10 Programmer for many processors: http://robokitsworld.com/index.php?m...fl6nbiqsr52nu0 $50 programmer (USB/serial): http://www.hobbyengineering.com/H3317.html Real Microchip programmers: PicKit2 (directly integrates with Microchip's development system): http://www.microchipdirect.com/Produ...mid=1&treeid=6 $220 Microchip In Circuit Debugger: The latest version is the ICD3. I use the ICD2 for most of my development work. http://www.microchipdirect.com/produ...?Keywords=icd3 To use the Pickit2 or ICD2/3 you have to add a header (or RJ11 jack) to your board to connect to. The two third party programmers allow you to plug the DIP package IC's in for programming. |
I ♥ Yaris
Drives: Black 08 LB MT & red 97 Miata Join Date: Oct 2008
yes, $50 for just the chip would be way too much, an aftermarket tach would cost less. The Propeller version, however, sounds right up my alley... I think it would look good with rectangle or square LEDs (or rectangle shaped covers) closely set together. It would be awesome to somehow incorporate it into the gauge cluster...
The trouble with the world is that the stupid are cocksure and the intelligent are full of doubt. - Bertrand Russell |
#12 | |
MetalShark
Cheaper, Better, Easier
#13 | |
MetalShark
work-in-progress
| P0456 OBD code? | jlift | DIY / Maintenance / Service | 6 | 09-19-2007 03:28 PM |
| Anybody know the code? | Driver | New YARIS Purchase Forum | 5 | 08-20-2006 06:56 PM |
