Old 04-10-2009, 10:06 AM   #1
mrbond
mrbond's Avatar
the diagrames above is for useing the switch supplied with the kit .
if you want to use the factory combo switch all you need is the relay
(factory , or aftermarket) to plug into factory position as per diagrames.
So, let's see if I understand this. If I wanted to use the factory stalk instead of the little button that goes into the console, then all I need to do is wire up the fog lights, put the wire into the fuse box in the engine bay, and then put the relay where it's supposed to go? So I wouldn't even need that extra wiring harness for the cabin? If so, that's fantastic.
- A Toyota Yaris
- A whut Yaris?
Old 04-10-2009, 08:01 PM   #2
Meteorite_Marty
Drives: 2008 5-door Yaris Hatchback
exactly the Yaris is already prewired, the only harness you need is the one to connect the Fogs together and to the fuse box in the engine bay.
Purchase the foglight stalk. The install is SOOOOOO much simpler and no messing with firewall and interior wiring. Plus, the fog light stalk is how it would come if you ordered your car with fogs from Toyota factory directly.
Meteorite_Marty is offline   Reply With Quote
Old 04-10-2009, 08:02 PM   #3
Meteorite_Marty
Purchase the foglight stalk, I don't think the default headlight stalk can handle fog light control. The install is SOOOOOO much simpler and no messing with firewall and interior wiring. Plus, the fog light stalk is how it would come if you ordered your car with fogs from Toyota factory directly.
Old 04-10-2009, 08:54 PM   #4
mrbond
mrbond's Avatar
For sure, I'm definitely doing this. I don't like messing with electrical stuff - too complicated.
- A Toyota Yaris
- A whut Yaris?
Old 04-10-2009, 10:06 PM   #5
Meteorite_Marty
This post gives links to order the RELAY and FOG LIGHT STALK
http://www.yarisworld.com/forums/sho...og+light+stalk
Speakers wires : how to identify + and - ? hystria In Car Entertainment + Electronics (audio / video / alarm) 23 05-27-2017 10:43 PM
DIY: LED side mirror installation eTiMaGo DIY / Maintenance / Service 85 06-24-2011 11:48 AM
Installing a remote starter without cutting factory wires? yaris08ce In Car Entertainment + Electronics (audio / video / alarm) 36 04-23-2009 08:59 PM
Ground Wires dngz Performance Modifications 8 11-26-2006 11:54 PM
Q about Routing wires to the engine compartment W.A.S.P In Car Entertainment + Electronics (audio / video / alarm) 10 11-01-2006 07:36 PM
