Not with his transmission. Also, even a used ECM would be more expensive then the aftermarket cruise kit.
My R1 eats my Vitz!!
Drives: '07 Vitz Lifty, Stick Shift Join Date: May 2007
I see...good to know :)
My Car Rules! |
![]() ![]() ![]() Drives: 09 Yaris 3 Dr White LB Join Date: Mar 2009
is it possible to order the side cover piece from the factory with the hole already there? I am sloppy with a drill and dremmell and don't want a hack job.
#4 | |
This is for one that has the hole for factory cruise control. |
Damn man that's awesome...PM sent.
Thanks so much for all the help with this project. It's not so bad being the guinea pig on something when you have so much knowledgable help on the subject. Hopefully we can get this thing hooked up and write up a nice DIY for the other "cruise control-wire-missing" drivers here :)
My Car Rules! |
![]() ![]() ![]() ![]() Drives: 2008 meteorite hatchback Join Date: Nov 2008
Alright, so just to sum it up for the stalk usage: I remove the airbag, install the stalk like in that Matrix link, then run a wire from the D connector to a ground point, and then the other wire straight to pin #40 in the ECM?
Do I mess with A21, or do I just do what I wrote in the above paragraph? (and this is all just if I don't bother with the clutch switch just yet)
- HOOOEY! That's one tahny little cawr! What the heck kinda toy is that? - A Toyota Yaris - A whut Yaris? |
#7 | |
Remember that in order to even test it, you will need to bypass the clutch switch at the under hood fuse panel connector. |
^ right, you said to jumper it to the white wire 2 pins over? What do you mean by jumper?
nickhjort, did you find any connector for the wiring to the clutch switch? Been searching for it for a few hours and haven't found anything. I believe that only the 09+ mt Yarii have that plug just hanging there...
Also, what is the function of the white wire you jumped the blue clutch switch wire to? Did you just do like what CTScott said and stuffed one wire into both pins?
Yeah basically I just used a thick guage wire I had laying around, that just happened to have a fuse on it, and just stuck it in there. You probably don't need the fuse, but what the hell...you can never have too many fuses right :) And no I didn't find the clutch switch connector under there either. I am still going to buy the stock switch though and just wire it to where I have the jumper in the fuse box. Basically what the switch does is acts as the jumper wire...only it's a reversed switch. So when you hit the clutch it kills the circuit (just like if you were to pull the jumper wire while using cruise control) Here's some pics of my jumper. Also make sre you put some spade connectors on the ends of your wire. They fit in there perfectly, nice and tight to ensure it doesn't come loose.
![]() ![]() Hope it helps
My Car Rules! |
PS... Make sure whatever you use as a jumper will fit under there whenever you put the fuse box cover back on :) Mine just barely fits.
My Car Rules! |
so thats all you have to do to bypass the secondary clutch switch for the MT?
#14 |
Wow, that actually cleared things up a lot, thanks!
#15 |
Yup that's it and everything to bypass the MT clutch switch. Now if you are using cruise control and you hit the clutch the engine will rev like a mofo since there's no switch to stop it...so don't hit the clutch! Unless you wanna blow shit up
My Car Rules! Last edited by nickhjort; 05-09-2009 at 06:46 PM. |
#16 |
so instead going through the hassle of buying the secondary clutch switch for the cruise, I should be able to use those two jump points in the fuse box and wire a momentary button to shut it off? and then I can just press the "on" and "set" to start the cruise again?
#17 | |
Actually, just press set again (or resume if you do the four button method). Only on/off or the keyswitch completely clear cruise mode. |
#18 |
yeah, I bought the OEM stalk
| DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag | CTScott | DIY / Maintenance / Service | 307 | 04-04-2023 04:43 AM |
| DIY Cruise Control on 07-08 Yaris (step by step) | Vince87 | DIY / Maintenance / Service | 431 | 12-28-2020 02:37 AM |
| Cruise Control - Again! | CB900F2 | DIY / Maintenance / Service | 47 | 06-17-2010 07:29 PM |
| Cruise control vs MPG | YarisOwnersDad | Fuel Economy Forum | 15 | 05-29-2009 04:55 PM |
| Using Cruise control | Driver | General Yaris / Vitz Discussion | 14 | 11-09-2006 11:12 PM |
