Old 05-12-2009, 08:43 PM   #11
Originally Posted by AlexNet0 View Post
so instead going through the hassle of buying the secondary clutch switch for the cruise, I should be able to use those two jump points in the fuse box and wire a momentary button to shut it off? and then I can just press the "on" and "set" to start the cruise again?
Actually, just press set again (or resume if you do the four button method). Only on/off or the keyswitch completely clear cruise mode.
DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag CTScott DIY / Maintenance / Service 307 04-04-2023 03:43 AM
DIY Cruise Control on 07-08 Yaris (step by step) Vince87 DIY / Maintenance / Service 431 12-28-2020 01:37 AM
Cruise Control - Again! CB900F2 DIY / Maintenance / Service 47 06-17-2010 06:29 PM
Cruise control vs MPG YarisOwnersDad Fuel Economy Forum 15 05-29-2009 03:55 PM
Using Cruise control Driver General Yaris / Vitz Discussion 14 11-09-2006 10:12 PM
