Old 05-12-2009, 08:38 PM   #11
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
Originally Posted by nickhjort View Post
Yup that's it and everything to bypass the MT clutch switch. Now if you are using cruise control and you hit the clutch the engine will rev like a mofo since there's no switch to stop it...so don't hit the clutch! Unless you wanna blow shit up
so instead going through the hassle of buying the secondary clutch switch for the cruise, I should be able to use those two jump points in the fuse box and wire a momentary button to shut it off? and then I can just press the "on" and "set" to start the cruise again?
DIY Cruise Control on 07-08 Yaris (step by step) Vince87 DIY / Maintenance / Service 431 12-28-2020 01:37 AM
Cruise Control - Again! CB900F2 DIY / Maintenance / Service 47 06-17-2010 06:29 PM
Cruise control vs MPG YarisOwnersDad Fuel Economy Forum 15 05-29-2009 03:55 PM
