What?
Oil preferences and oil changing habits are one of the "holy wars" of every automotive forum. You'll never get a concensus.
I doubt that the factory fill oil is anything special, just bulk oil of the correct spec. I also doubt that there's any benefit to changing it before 5k miles, but do it if it makes you happy. I DO have an opinion on synthetic oil, however. Every engine needs to break in for optimal performance. If you switch to synthetic oil too soon, you stop or at least greatly hinder the break-in process (yes, synthetic oil is that good). If you're going to use synthetic oil, wait until after 5k miles to switch. Then (holy war point again), aside from the warranty requirement to change the oil at 5k, you can get away with 10k synthetic oil changes if you want. |
If the engineers who designed the engine say to change the oil at 6000 miles/10000kms thats good enough for me i'll presume they know more about the engine than i do .
#4 | |
![]() Drives: 2009 Yaris 3 door hatchback Join Date: Jun 2009
Crazy Oil Sniffer
Drives: MM 09 Yaris 5 Dr LB "Click" Join Date: May 2009
TheSilkySmooth,
I'm not sure why you've had the bad luck with the Densos but I was concerned enough I was going to get the same supply in Maine that I ordered a bunch of Nippons. (Supposed to be like OE but made in Malaysia under Japanese management.) I've always had good luck with Denso OE stuff in other apps. |
#7 | |
I love momentum.
#8 | |
Audio Junky
When I reach 80,000 miles and my warranty is up i'll be running an expensive synthetic (probably API V oil... tho use it for probably 15,000 with filter changes every 5,000 miles... will end up being cheaper... and just as good if not better than dino every 5,000) |
Tw200--excellent!
Drives: 2010 yaris..absolutely red. Join Date: Jun 2010
Get the metal bits out!.....save your engine.
![]() ![]() Drives: 07 Yaris Sdn, 97 4Runner Join Date: Jul 2006
I changed my oil for the first time at 1,500 miles. I immediately switch to Mobil 1 5w-30. As soon as I discovered Mobil 1 0w-30, I switched to that. I started the Amsoil 0w-30 SSO at 85k and drained at 95k. This time, I'm going for a 15k mile oil change interval. I started with Toyota oil filters and switched to Mobil 1 oil filters once I started the extended oil change intervals.
I changed my manual transmission fluid at 70k the first time. I actually forgot about doing it and then realized I should have done it way earlier. The synchros went at 90k and a new/used transmission was installed. Now I will change it every year and use Amsoil's 75w-90 gear oil. |
| DIY: CHANGE MANUAL TRANNY OIL | ttufrosty | DIY / Maintenance / Service | 157 | 09-07-2018 01:43 PM |
| Help with oil change specs | autophile | DIY / Maintenance / Service | 31 | 04-25-2011 09:22 PM |
| Oil Change Issue. | Twistoffate0817 | General Yaris / Vitz Discussion | 56 | 05-05-2009 10:27 AM |
| Oil change time... yay! | YarisFan007 | DIY / Maintenance / Service | 10 | 09-19-2007 05:40 AM |
