Old 04-15-2009, 08:05 AM   #19
schleppy
I love momentum.
schleppy's Avatar
Drives: 2009 Yaris LB, Red
Originally Posted by Loren View Post
Oil preferences and oil changing habits are one of the "holy wars" of every automotive forum. You'll never get a concensus.
I doubt that the factory fill oil is anything special, just bulk oil of the correct spec. I also doubt that there's any benefit to changing it before 5k miles, but do it if it makes you happy.
I DO have an opinion on synthetic oil, however. Every engine needs to break in for optimal performance. If you switch to synthetic oil too soon, you stop or at least greatly hinder the break-in process (yes, synthetic oil is that good). If you're going to use synthetic oil, wait until after 5k miles to switch. Then (holy war point again), aside from the warranty requirement to change the oil at 5k, you can get away with 10k synthetic oil changes if you want.
I'm 100% with you on this one. I will do at least the first three oil changes using dino, then consider switching to synth.
DIY: CHANGE MANUAL TRANNY OIL ttufrosty DIY / Maintenance / Service 157 09-07-2018 01:43 PM
Help with oil change specs autophile DIY / Maintenance / Service 31 04-25-2011 09:22 PM
Oil Change Issue. Twistoffate0817 General Yaris / Vitz Discussion 56 05-05-2009 10:27 AM
Oil change time... yay! YarisFan007 DIY / Maintenance / Service 10 09-19-2007 05:40 AM
Motor oil debate - interesting info but a long read. mikeukrainetz General Yaris / Vitz Discussion 6 12-10-2006 08:16 PM
