#1 | |
Drives: 2007 Yaris Hatchback Join Date: Oct 2008
The fact is, the ONLY difference is that the 0w protects better during very cold weather during start ups. As to operational oil temperatures (180f to 212f and above) the 5w and 0w both protect the same because they are both 20 weight on the high end of the viscosity range. So at hot operational temperatures, 0w-20 and 5w-20 provide the same protection. |
#2 | |
You're still confused
#3 | |
It's about the additive packages, and not the viscosity. Now as time goes on, more 0w-20 brands will be good for the Yaris, but today not all. |
#4 | |
Toyota (USA) Demands API approval
Show me where Toyota says do NOT use 0w-20 because of additive packages, but use 5w-20 and 5w-30 for the Yaris (1NZ-FE) because their additive packages pown 0w-20's...all I see in Toyota's TSB is that they will allow 5w-20 but NOT 0w-20 in the Yaris motor, and there have never been little footnotes about *additive packages* as far as I can tell, plus you've ALWAYS stated that the TSB states 5w-20 is okay, so "with that being said 0w-20 is okay because it performs exactly like 5w-20" without ever mentioning certain additive packages in certain oil brands being the deciding factor. And why would you use Amsoil 0w-20? It's not API approved...hmmmm...but the Amsoil XL 5w-20 is API approved ...bet that's another reason why the Toyota TSB says yes to 5w-20 and no to 0w-20. Bottom line: Until the TSB says yes to 0w-20 it's wrong to use it, but keep using it year round in southern California. ![]() You must wake up in a new world every day. How many times have you claimed that brand doesn't matter, that the cheapest discount synthetic will make an engine last just as long as an expensive synthetic, like Royal Purple? I'm not the one that's confused; I use API certified oil, and the proper viscosity, you don't.
![]() 1997 Lincoln Town Car - SOLD 2008 Scion xD (w/ automatic) - SOLD 2008 Yaris HB - SOLD Last edited by 1stToyota; 04-24-2009 at 10:28 AM. |
#5 | |
ADDITIVE PACKAGE. For example, this is why SL grade 5w-30 can be run in car X but not car Y, yet BOTH cars call for 5w-30, but not ANY 5w-30. So if two oils are 5w-30 yet only one can be run in car X, why? ADDITIVE PACKAGE differences. There are cars out there that call for a particular brand of 5w-30 or 5w-20 or 0w-20 because not any brand will do even if the viscosity range is perfect....why? Additive package differences, again. |
#6 | |||||||
Don't backup now...you said Toyota will allow 5w-20 but not all 0w-20's because of an additive package issue. LOL!
#7 | |
However this thread is about 0w-20 vs. 5w-20. In regard to this particular and specific issue, brand does in fact matter because not all brands provide the appropriate additive packages required by certain cars. Now if one wants to use oils found in their manuals/TSBs (5w-20, 5w-30) in their Yaris then as long as the oil is either made by AMSoil or is API-SM certified, then BRAND DOES NOT MATTER. For example, when I run 5w30 or 5w-20 the brand of the synthetic does not matter. But for 0w-20 the only brands I will use are Mobile1 and AMSoil. This is the EXCEPTION, and not the rule. Hope this clarifies. |
#8 | |
![]() I've never seen you make viscosity distinctions until now, when I called you on it. And they have to have the appropriate additive packages to even produce a 0w-20 viscosity, fyi. And as in certain cars, our 1NZ-FE Yaris? Still haven't seen where Toyota lists 0w-20 for it yet. And, again, stick to that lose/lose formula of: 1) Use an Amsoil grade that isn't API approved 2) Use a viscosity that isn't listed on Toyota's TSB
| best synthetic oil and m/t oil?? | doodoo | DIY / Maintenance / Service | 122 | 04-03-2017 09:43 PM |
| Help with oil change specs | autophile | DIY / Maintenance / Service | 31 | 04-25-2011 10:22 PM |
| Synthetic Oil | Kaotic Lazagna | DIY / Maintenance / Service | 122 | 09-20-2007 04:40 PM |
| metal particles in oil | 007 hatch | DIY / Maintenance / Service | 9 | 06-22-2007 03:56 AM |
| Motor oil debate - interesting info but a long read. | mikeukrainetz | General Yaris / Vitz Discussion | 6 | 12-10-2006 09:16 PM |
