#19 |
![]() ![]() ![]() Drives: Yaris Join Date: Apr 2009
I will be getting some 08' sedan foglight covers from Garm but once I am done setting up the foglight wiring, I don't want to have to put my bumper back on without the correct shrouds. Can/Do the shrouds get popped on after the bumper is installed? Or, can you pop on the shrouds after the bumper is installed? This way....I can do all the work and if the 08' sedan shrouds don't fit, I can get the correct 09' shrouds and just pop them on. Anybody?
#20 |
#21 |
![]() ![]() ![]() ![]() Drives: 2009 Yaris Hatchback Join Date: Feb 2009
I have an '09 LB. If I buy this kit from Garm: http://shop.microimageonline.com/pro...&productId=111 all I would need is the LH & RH shrouds and the OEM stalk from Toyota to make it work?
#22 |
#23 |
#24 |
#25 |
That's what I figured. Is it this one? http://shop.microimageonline.com/pro...&productId=111
Will this kit work with the '09 3 door LB if I get the shrouds from Toyota? |
#26 | |
The OEM trim pieces are the only thing needed to make it work on an 09. |
#27 |
Thanks, that's what I was curious about. I wasn't sure if it was the sedan or liftback version that worked on the 09 so thanks for clearing it up. Any idea where I can find the OEM cruise stalk on the cheap? The dealer wants $115.18.
#28 |
Scott,
I plan on using the integrated fog light switch on the headlight stalk for total plug and play. Do you happen to know if the 08 sedan covers will fit the 09 LB? If you know for sure....I may as well go ahead and order the right ones now.
#29 | |
For the cruise stalk, check this ebay auction: http://cgi.ebay.com/ebaymotors/NEW-O...Q5fAccessories |
#30 |
Initially, I thought that might be a possibility as well, but no the sedan covers are different than the 09 liftback ones.
#31 |
#32 | |
#33 | |
The other place to try is the junkyard that I bought my wiper stalk from (for $50 vs ~$100). http://autoworksinc.com/ |
#34 |
They also have the 09 version (84140-52151) for $92.14. Price difference is $15.20. You're the electrical genius... which switch would you use? The TRDsparks item description for the 52150 says 'combo switch w/ fog lamps' but the 52151 description only says 'SWITCH ASSY HEADLAM' so I'm worried it might not be the right one.
#35 | |
#36 |
Thanks for all your help. Now I just need to order the shrouds. Is there a DIY for installing the fogs with the OEM stalk? All I found were DIYs for using the aftermarket switch.
| DIY (08' USDM Liftback): ESUSE Fog Light Install v2.0 | goku87 | DIY / Maintenance / Service | 127 | 02-19-2023 08:01 PM |
| Compilation of Yaris How-tos/DIYs | YarisBueller | DIY / Maintenance / Service | 39 | 04-28-2018 09:47 AM |
| Fog light install | 07yaris_fe | Cosmetic Modifications (Exterior/Interior) | 10 | 07-20-2010 02:18 PM |
| Looking for the Toyota Fog Light install | RocknRollRon | DIY / Maintenance / Service | 33 | 06-13-2010 07:46 PM |
| srs / airbag light after head unit install? | KwonSau | In Car Entertainment + Electronics (audio / video / alarm) | 7 | 12-24-2008 03:04 AM |
