#19 |
Giupo,
I'm currently using the E-Manage Blue for my turbo, and the MAF volt is clamped at 4.95v. Do you have a MAP sensor as well? If budget permits, you may want to add a MAP sensor as another input for your Ultimate and tune your car off its reading as well. You can achieve a much more accurate tune with a MAP sensor rather than relying on the TPS readings. But in your case, you have the boost harness as well, which is cool. If you don't want to go standalone but yet you want to remove the MAF altogether, you could consider using the HKS F-CON V Pro. It allows you to remove the MAF physically.
454 whp, 1.7 bar boost, pump gas, water/meth. 501 whp, 2.2 bar boost, pump gas + avgas, no water/meth. www.viosturbo.com - World's first 500 WHP 1NZ-FE |
#20 |
![]() ![]() Drives: Yaris Join Date: Apr 2009
For CTScott
Excuse me but my MAF arrive at 4.9v..Thank you very much |
#21 | |
I have the Greddy E-manage Ultimate and use the Greddy sensor pressure..I can eliminate the maf with this greddy ecu but I need the Maf value.. |
#22 |
#23 |
ok, the maf sensor arrive at 4.9v at 6000 rmp but at between 4000-5000rpm the Maf value 3.94v I avvert the slightly engine brake but the A/F ratio is good..
#24 | |
The question is why does yours clip between 4K and 5K, but then stop clipping above that? |
#25 |
I don't know because the maf clip between 4000 and 5000 Rpm, before 4000 rpm e after 5000 rpm the engine is good... I suppose that between 4000 and 5000 Rpm the engine is at max of Tourque.
#26 | |
l33t3st Asshole
Drives: MY07 Yaris Liftback Join Date: Nov 2006
do you have any datalogging showing your MAF logs based on load and RPM? |
#27 |
#28 | |
#29 |
Thank you very much :)
#30 | |
#31 |
Bump... I never noticed this thread. Might be useful.
#32 |
I'm getting this same problem. Has anyone ever data logged the MAF voltages on a NA engine?
I'm getting clipping at random RPMs but I did a log and if I floor it, the MAF spikes to 3.9V and that's when the hiccups occur. This can be anywhere from 2000 to 5000 RPM. Odd thing is, the MAF will still read all the way up to 4.4V without any hiccups sometimes. |
#33 | |
#34 |
FIC
I haven't tried building a MAF voltage table yet. Haven't had time. |
#35 |
Only maps you should be using are the o2 and fuel maps. Maf clamp is in the setup menu and should be set at 4.95. unless you have the maf in a bigger or smaller pipe that is what the maf table is for. aem does not really go over this and it causes alot of people problems.
#36 | |
The MAF table allows you to set the voltage output based on the voltage input. So you can have it read exactly as it should up to the point where the turbo starts drawing in more air than a NA engine would and makes it freak out, clamping the voltage at a set RPM. I've had this problem even before I had an FIC installed. I've even run the car without the O2 sensor hooked up and just the FIC making fuel adjustments. |
| Turbo Kit - trade for stock parts! | crankyelbow | Items for Sale by private party | 62 | 02-03-2009 12:30 PM |
| $2500 Turbo Kit is back to life! | bdc87 | Forced Induction Forum | 8 | 10-20-2008 09:46 AM |
| Under $2500 Turbo Kit w/Intercooler coming soon! | cdydjded | Forced Induction Forum | 58 | 09-23-2007 02:02 PM |
| ZPI to produce yaris turbo kit and exhaust | turboyaris | Forced Induction Forum | 15 | 06-09-2007 01:24 AM |
| ZPI to produce yaris turbo kit and exhaust | turboyaris | Forced Induction Forum | 30 | 04-04-2007 02:10 PM |
