Old 04-17-2009, 09:39 AM   #1
Giupo
MAF Cliping with Turbo Kit
Hi, I have a Yaris 1nzfe with:
Greddy turbo
Greddy emanage ultimate with sensor pressure
Injector 380cc
Fuel pump
Cp pistons 9:1 cr
Pauter roads
Cams
Greddy elettronic overboost
I have mapped with 18 psi turbo pressure but the MAF between 3500 - 4500 rmp is cliping.
Could I eliminate the toyota Maf?
Thanks
Giupo is offline   Reply With Quote
Old 04-17-2009, 11:25 AM   #2
Please post pictures, especially of the cams, and dyno chart.
Where did you get the head studs for your build?
Old 04-18-2009, 08:14 AM   #3
Giupo
Sorry but I don't have a dyno charts because i want eliminate the Maf sensor because it is a problem at 3500 rmp the car is block and i want know if the problem is the MAF or O2sensor under 10psi the problem don't have but up 10 psi have this problem.
Thanks
Old 04-18-2009, 09:59 AM   #4
scioncrew
scioncrew's Avatar
Drives: SCION tC
Send a message via AIM to scioncrew
I dont think the Greddy emanage will lit you bypass the MAF it kinda needs it. Im not an expert with MAF sensor's but i think to fix your problem your going to need a bigger higher flowing MAF. Your only other option that will eliminate the MAF is to go with a full standaloan EMS. ( AEM,MOTEC,HYDRA ect.)
Regard
Arthur
05 Scion tC allmotor 350+ hp 9.34@144mph
05 Scion tC sfwd 880hp 9.96@147mph
05 Scion xB 280hp 12.97@104mph
07 Toyota Yaris 357hp 12.80@107mph
scioncrew is offline   Reply With Quote
Old 04-18-2009, 11:01 AM   #5
Nexus1155
Bathroom + Laptop = <3
Drives: Audi
Yeah I highly doubt it is the O2 sensor, most likely it is the MAF sensor. It is scaled for only so much air, unless you can install a larger MAF and scale the curve for the added g/s of airflow, then you need to lose it and put a MAP sensor in there...
Good Luck!
Old 04-18-2009, 05:36 PM   #6
Giupo
Thanks for your answer..
The problem is the MAF sensor, with greddy Emanage Ultimate I can eliminate the MAF sensor with "Airflow Output" map but I have need of the values of the MAF sensor with stock engine ( volt at all RPM).
Someone could help me?
Thanks
Old 04-18-2009, 06:34 PM   #7
Don't know that curve. Someone will know the range though.
Old 04-21-2009, 05:56 AM   #8
Giupo
Who knows the 1NZ-FE MAF voltage range?
Thanks
Old 04-21-2009, 09:48 AM   #9
kurokoma-kun
Drives: 2007 Yaris HB
You mean just the normal operating range? The manual says its between 0.4 V and 2.2 V
Old 04-21-2009, 10:16 AM   #10
Russelt3hPirate
l33t3st Asshole
Russelt3hPirate's Avatar
Drives: MY07 Yaris Liftback
where in the turbo routing did you mount the MAF?
what size is the MAF housing?
it's possible you're maxing out the MAF's readings and you need to go to a larger diameter MAF housing and retune.
or you could be having issues if it's
A.) too close to the turbo inlet
B.) Blow thru (after the turbo outlet)
C.) bad maf
Russelt3hPirate is offline   Reply With Quote
Old 04-21-2009, 11:30 AM   #11
From what I've seen the MAF voltage vs RPM plots are pretty linear, so based on the normal operating range of 0.4 to 2.2, you could start with the following:
100 0.4
200 0.430508475
300 0.461016949
400 0.491525424
500 0.522033898
600 0.552542373
700 0.583050847
800 0.613559322
900 0.644067797
1000 0.674576271
1100 0.705084746
1200 0.73559322
1300 0.766101695
1400 0.796610169
1500 0.827118644
1600 0.857627119
1700 0.888135593
1800 0.918644068
1900 0.949152542
2000 0.979661017
2100 1.010169492
2200 1.040677966
2300 1.071186441
2400 1.101694915
2500 1.13220339
2600 1.162711864
2700 1.193220339
2800 1.223728814
2900 1.254237288
3000 1.284745763
3100 1.315254237
3200 1.345762712
3300 1.376271186
3400 1.406779661
3500 1.437288136
3600 1.46779661
3700 1.498305085
3800 1.528813559
3900 1.559322034
4000 1.589830508
4100 1.620338983
4200 1.650847458
4300 1.681355932
4400 1.711864407
4500 1.742372881
4600 1.772881356
4700 1.803389831
4800 1.833898305
4900 1.86440678
5000 1.894915254
5100 1.925423729
5200 1.955932203
5300 1.986440678
5400 2.016949153
5500 2.047457627
5600 2.077966102
5700 2.108474576
5800 2.138983051
5900 2.169491525
6000 2.2
Old 04-22-2009, 05:20 AM   #12
Giupo
C.) bad maf
The MAF housing is 2.20"
Old 04-22-2009, 05:25 AM   #13
Giupo
For CTScott
thank you very much for the value but my toyota MAF sensor is 0,2v at 4,9v.
Old 04-22-2009, 06:51 AM   #14
Originally Posted by Giupo View Post
For CTScott
The output of the sensor can go from 0.2 to 4.9, but the "normal range" goes to 2.2 V.
Old 04-22-2009, 07:28 AM   #15
Have you measured the MAF voltage where the clipping occurs?
Old 04-22-2009, 09:13 AM   #16
Giupo
yes is 3,94 volt at 4200rmp
Old 04-22-2009, 09:21 AM   #17
Giupo
I have use the "Boost limiter cut" map but the engine between 4000 and 5000 rpm refrains slightly.. the A/F ratio is good
Old 04-22-2009, 11:00 AM   #18
OK. So, it that case I would scale it from 0.4 to 3.90 volts:
100 0.400
200 0.459
300 0.519
400 0.578
500 0.637
600 0.697
700 0.756
800 0.815
900 0.875
1000 0.934
1100 0.993
1200 1.053
1300 1.112
1400 1.171
1500 1.231
1600 1.290
1700 1.349
1800 1.408
1900 1.468
2000 1.527
2100 1.586
2200 1.646
2300 1.705
2400 1.764
2500 1.824
2600 1.883
2700 1.942
2800 2.002
2900 2.061
3000 2.120
3100 2.180
3200 2.239
3300 2.298
3400 2.358
3500 2.417
3600 2.476
3700 2.536
3800 2.595
3900 2.654
4000 2.714
4100 2.773
4200 2.832
4300 2.892
4400 2.951
4500 3.010
4600 3.069
4700 3.129
4800 3.188
4900 3.247
5000 3.307
5100 3.366
5200 3.425
5300 3.485
5400 3.544
5500 3.603
5600 3.663
5700 3.722
5800 3.781
5900 3.841
6000 3.900
Turbo Kit - trade for stock parts! crankyelbow Items for Sale by private party 62 02-03-2009 12:30 PM
$2500 Turbo Kit is back to life! bdc87 Forced Induction Forum 8 10-20-2008 09:46 AM
Under $2500 Turbo Kit w/Intercooler coming soon! cdydjded Forced Induction Forum 58 09-23-2007 02:02 PM
ZPI to produce yaris turbo kit and exhaust turboyaris Forced Induction Forum 15 06-09-2007 01:24 AM
ZPI to produce yaris turbo kit and exhaust turboyaris Forced Induction Forum 30 04-04-2007 02:10 PM
