Old 05-03-2009, 07:09 PM   #1
Liu997
Drives: 2008 Red Yaris LB
Ok my fogs are finally working. Are the foglights supposed to light up even when the light stalk is switched off? Mine only light up when the panel or headlights are on.
Also I got it to work without soldering the two jumpers, but the square light won't go on. The reason I did that is because when I soldered the jumpers, the foglights were on regardless of switch positon. And when I pressed it a buzzing sound came from under the steering wheel.
And, I couldn't find the diode on mine. Heres how my switch looks like currently
Liu997 is offline   Reply With Quote
Old 05-03-2009, 08:04 PM   #2
Fogs only come on with the low beam headlights.
You have to also cut/desolder the connection between the blue-green and green-black pads (and add those two jumpers) for the lighting to work correctly.
Old 05-04-2009, 10:51 PM   #3
Liu997
By that you mean this right?
Old 05-04-2009, 11:06 PM   #4
Correct.
Old 05-06-2009, 12:03 PM   #5
cyberfrogg
cyberfrogg's Avatar
Drives: Yaris Sedan S
Liu, did it work? I've been wanting to try it out but I haven't had the chance.
cyberfrogg is offline   Reply With Quote
Old 05-06-2009, 08:04 PM   #6
Liu997
Sorry, didn't have time. I have so much work to do lately. I will try it this wkend, ill get back to you
Old 05-07-2009, 11:15 AM   #7
cyberfrogg
cyberfrogg's Avatar
okay thanks. I'm really hoping this works.
Old 05-07-2009, 09:38 PM   #8
Liu997
Tried this, This is the most I can explain lets go With the switch on
1. The minute I plugged it in all panel lights come on.
2. The lights come on in addition to a buzzing sound coming from under the steering wheel, most likely a relay or near the fuse box.
3. When I turn the panel lights on I see a spark (because I plugged it in without the cover but shouden't be a problem.) and the jumper listed below disconnects. I have done everything you have said.
4. See picture.
Old 05-07-2009, 10:01 PM   #9
Move the jumper that is over the "es" of resistor (at the top right) to the "o" of resistor.
Is the solder and trace under it gone between all of the three groups of two switch contacts?
Old 05-09-2009, 12:11 AM   #10
Liu997
The same thing happens this is a real picture on my switch. Mind the circuit writer, that is because I accidentally cut off a trace
Old 05-09-2009, 10:09 AM   #11
Getting close. Look at the picture below. This is what I mean about separating the three groups of two contacts for the switch. This isolates the switch circuit from the lighting circuit.
Also, since you used non-insulated wire for your jumpers, make sure that they do not touch anywhere except for at the ends.
Old 05-09-2009, 07:08 PM   #12
Liu997
but should the two groups of three contacts touch or should nothing touch anything else
Old 05-09-2009, 07:44 PM   #13
Liu997
The picture is how my switch is now. Still not working
Now everything functions like normal but the square light doesn't turn on no matter what.
Old 05-09-2009, 08:14 PM   #14
Does the Fog light symbol light up?
Old 05-09-2009, 08:45 PM   #15
Liu997
yes, only when I turn the panel lights on and headlights
Old 05-09-2009, 10:49 PM   #16
Can you take a picture of the other side of the switch circuit board?
Old 05-09-2009, 10:24 PM   #17
Treyz
~ ambient one ~
Treyz's Avatar
It's been so long that I don't even remember what I did lol ....
Don't be surprised if the lamps break on ya. Had it done twice before I finally ordered the Toyota OEM lamps.
AMBIENTLIFESTYLE
Tri-State Sport Compact EZine
Micro Image
Store - Network - Online
Old 05-10-2009, 11:26 AM   #18
Liu997
How do I do that. It seems like I can't take out the board
Part #s for Fog Light install? Can anyone who works for Toyota confirm? IsLNdbOi Cosmetic Modifications (Exterior/Interior) 73 12-23-2010 05:15 PM
test fit 06-07 Yaris 4 door fog light winson California 15 01-13-2009 08:25 PM
DIY:Day time running light Disabled with stock fog light remain function summergxz DIY / Maintenance / Service 12 09-26-2007 10:42 AM
Reverse light vs Rear Fog light cooldavidko General Yaris / Vitz Discussion 3 01-03-2007 03:09 AM
