Old 04-25-2009, 04:16 PM   #1
Liu997
Drives: 2008 Red Yaris LB
Fog light help please
I used this DIY on Yarisworld http://www.yarisworld.com/forums/showthread.php?t=9473
I have the same problem of that the switch led won't turn off even if you turn off the car.
There was an explanation but I didn't quite understand. Where do you get the red wire and the white wire from?. I currently followed exactly as says. Thanks in advance.
Liu997 is offline   Reply With Quote
Part #s for Fog Light install? Can anyone who works for Toyota confirm? IsLNdbOi Cosmetic Modifications (Exterior/Interior) 73 12-23-2010 05:15 PM
test fit 06-07 Yaris 4 door fog light winson California 15 01-13-2009 08:25 PM
DIY:Day time running light Disabled with stock fog light remain function summergxz DIY / Maintenance / Service 12 09-26-2007 10:42 AM
Reverse light vs Rear Fog light cooldavidko General Yaris / Vitz Discussion 3 01-03-2007 03:09 AM
