Old 05-13-2009, 06:22 PM   #1
powermicro
Drives: 2009 Toyota Yaris S 5-Door
DayTime Running Lights ISSUE!!!??!?!?!?!2009 5-door-hatch
Tried to turn OFF the daytime running lights by removing the relay box under the steering column. When i remove/unplug the box the lights then don't come ON(GOOD), but my fog lights then don't work. Is there a work around??
Thanks!!
powermicro is offline   Reply With Quote
Old 05-14-2009, 12:12 AM   #2
vten
find the orange wire on the harness you pulled off the light module, then connect it to any metal frame as the grounding.
wire tap is works too .
Day Time Running Lights rdobiash DIY / Maintenance / Service 4 01-22-2009 11:36 PM
how bright are the daylight running lights? anon Canada 11 10-26-2008 07:38 PM
Daytime Lights NimbleYarisOwner General Yaris / Vitz Discussion 17 08-24-2007 09:07 AM
Daytime running lamps suck Indianspringsaz General Yaris / Vitz Discussion 37 07-27-2007 04:29 PM
Does the Yaris come with............. Driver Cosmetic Modifications (Exterior/Interior) 7 08-21-2006 12:06 AM
