Old 10-20-2008, 03:27 PM   #1
anon
how bright are the daylight running lights?
As soon as you turn on the engine, are the main headlights supposed to be nearly as bright as or much dimmer than when you turn the switch all the way up?
anon is offline   Reply With Quote
Old 10-20-2008, 06:59 PM   #2
Treyz
~ ambient one ~
Treyz's Avatar
Dimmer than stock, but bright enough that they are visible from far. So I would say nearly as bright.
AMBIENTLIFESTYLE
Tri-State Sport Compact EZine
Micro Image
Store - Network - Online
Old 10-20-2008, 07:17 PM   #3
anon
Thanks. I'm trying to determine if my headlights have a problem since I accidentally cut a related wire in the fuse box and reconnected it. Right now my headlights seem quite bright when the engine is on, and the dimmer switch only causes the brightness to go up slightly when turned up, but maybe that was always the case. If others can provide similar feedback then I can rest assured it's working fine.
Old 10-20-2008, 07:20 PM   #4
Treyz
~ ambient one ~
Treyz's Avatar
Wait what? The dimmer switch brightens up your headlights?
What were you installing that you cut the wire accidently?
AMBIENTLIFESTYLE
Micro Image
Old 10-20-2008, 11:45 PM   #5
anon
Is the dimmer switch the thing that switches between low and high beam? Then sorry about the terminology, I meant the switch for the regular low beam. When I turn it up, the headlight doesn't get too much brighter.
I was installing a head unit with navigation and needed the speed sensor wire. One of the pictures shown by another user here pointed to the wrong wire which happened to be for the headlights.
Old 10-21-2008, 08:46 AM   #6
voodoo22
Drives: Yaris Sedan (auto)
Dimmer switch is used to control the brightness of the backlighting in the gauge cluster
voodoo22 is offline   Reply With Quote
Old 10-21-2008, 04:04 PM   #7
anon
"...headlamp dimmer switch. The dimmer switch allows the driver to select either the low beams or the high beams."
http://searchchicago.suntimes.com/au...etters.article
"If the dimmer switch is in the LOW position, current flows through the low-beam filament of the headlights. When the dimmer switch is in the HIGH position, current flows to the high beam headlights "
http://books.google.com/books?id=U4T...um=5&ct=result
Old 10-21-2008, 04:09 PM   #8
anon
Below says the daytime lights should use about half the voltage:
"Daytime Running Lights
...The system normally uses the vehicle's high-beam lights. The control circuit is connected directly to the vehicle's ignition switch so the lights are turned on whenever the vehicle is running. The circuit is equipped with module that reduces 12-volt battery voltage to approximately 6 volts. This voltage reduction allows the high beams to burn with less intensity... Applying the parking brake also deactivates the DRL system so the lights are not on when the vehicle is parked and the engine is running."
http://books.google.com/books?id=U4T...um=1&ct=result
Old 10-22-2008, 09:41 AM   #9
well, they are right and wrong.
Honda cars uses highbeam as DRL. so they run them on 6v so they do not blind people.
but our Yaris uses the lowbeam DRL, so they still run on 12v but limits the current so that the bulbs does not get full amperage.
Old 10-24-2008, 02:56 PM   #10
anon
applying the parking brake in my Yaris does not turn off the DRL. Is this normal?
Old 10-24-2008, 11:01 PM   #11
Pars
Drives: 07 Yaris Liftback
Once the DRL are on, you'll need to switch-off the car to stop em.
When starting-up the car, the DRL wont come on until you release the handbrakes.
Not sure about putting it into drive or gear with the handbrakes up (while engine is running). My guess, they'll still come on.
Pars is offline   Reply With Quote
Old 10-26-2008, 08:38 PM   #12
hehe anon: first time owner of a car with DRL ?
if so, i'm very surprised you did not question about the air bag first.
Question about lights kaymm General Yaris / Vitz Discussion 4 04-20-2020 10:10 PM
JUST GOT MY JDM TAIL LIGHTS!!!!! falkor_99 Cosmetic Modifications (Exterior/Interior) 12 10-01-2007 12:25 PM
CLUSTER LIGHTS WENT OUT Go4th DIY / Maintenance / Service 23 01-25-2007 12:37 PM
Smoke your own tail lights ChinoCharles Cosmetic Modifications (Exterior/Interior) 9 01-16-2007 12:00 AM
can i / where to get factory switch for aftermarket fog lights? and exhaust tip q. fantabulousbaby Cosmetic Modifications (Exterior/Interior) 22 08-29-2006 02:13 PM
