Old 05-18-2009, 01:37 PM   #1
Originally Posted by Stiv View Post
Last time I used these http://www.sharkoon.com/html/produkt.../index_en.html
It was done in Renault Laguna which has a dimmer.
They dimmed as expected and they're still working like a charm
That works. Another option that I like better than CCFL lamps is EL wire. It is flexible, won't break if you bump it, and extremely power efficient.
http://www.lightnwire.com/raw.html
Old 05-18-2009, 01:57 PM   #2
Stiv
Drives: Yaris TS 1,8L
That's tight
Do you know which one should have the same brightness as those CCFL I mentioned earlier? Maybe HIGH BRIGHTNESS STANDARD WIRE?
Stiv is offline   Reply With Quote
Old 05-18-2009, 04:49 PM   #3
That's tight
The high brightness standard should be very similar to if not brighter than the ccfl. The other handy thing about EL wire is that you can cut it to any length, whereas the ccfls come in set sizes.
Old 05-18-2009, 04:55 PM   #4
Stiv
Oh man, so nice, I just sent them an email. Hope they ship to Croatia :)
Old 05-18-2009, 07:15 PM   #5
If they don't, just do a web search for "EL wire". You should be able to find someone over in that area that carries it.
12 LED Dome Light Festoon bigsky2 Cosmetic Modifications (Exterior/Interior) 26 04-18-2010 10:38 AM
aveo dome light trouble TickleTimeTim Off-topic / Other Cars / Everything else Discussions 10 03-18-2009 01:08 AM
DIY:Day time running light Disabled with stock fog light remain function summergxz DIY / Maintenance / Service 12 09-26-2007 10:42 AM
Festoon (dome light) led bulb fit?? ||)) (o) ||\|| Cosmetic Modifications (Exterior/Interior) 5 03-22-2007 02:22 PM
