![]() ![]() Drives: 2008 Red Yaris LB Join Date: Nov 2008
Dome Light Wire
I am going to add some LED bars for interior lighting and don't know which wire is the dome light so that the bars will light up when the doors are open.
And can the circuit handle 4 led bars? Thanks |
no one has hook up lights to the dome wire? Its really that bad?
![]() ![]() ![]() ![]() Drives: Sc'd Yaris Sedan. Join Date: May 2007
While I can't speak for this exact situation, every time I've added light bars I ran them directly to a separate fuse box I attached directly to the battery. You can pick one up for a few bucks and you can set any fuse and any number of lights to it. I know that won't help your lights on with the door open idea but you could still rig something up for that afterward.
Tantum religio potuit suadere malorum. |
The feed is via a 15A fuse, so you should be fine. That circuit drives the dome, map, and hatch lights.
![]() ![]() Drives: Yaris TS 1,8L Join Date: Oct 2008
I think I have an idea.
I looked at the lightning diagram, and there is a connector called 4K left of the steering wheel. Wire 4K-2 is ECU controlled ground that controls the dome light dimming effect. It goes from 0V (dome light is on) to 12V (dome light is off). The idea is to hook + connector of the LED or cold cathode neon light to let's say cigarette lighter + wire (or any other available constant 12V wire), and - or ground to the 4K-2 wire. In theory that works. Please look at http://www.etimago.com/yaris/repairmanual/Lighting.pdf pages 19, 83 and 84. |
#6 | |
Last time I used these http://www.sharkoon.com/html/produkt.../index_en.html
It was done in Renault Laguna which has a dimmer. They dimmed as expected and they're still working like a charm |
#8 | |
That works. Another option that I like better than CCFL lamps is EL wire. It is flexible, won't break if you bump it, and extremely power efficient. http://www.lightnwire.com/raw.html |
#9 | |
![]() Do you know which one should have the same brightness as those CCFL I mentioned earlier? Maybe HIGH BRIGHTNESS STANDARD WIRE? |
I actually had some under dash lights hooked up to the dome circuit and I'd tell you which wire on the junction box it was if I hadn't disconnected it. I seem to recall it was a pink-ish wire. I know this doesn't help much but just know that it is possible and easy to wire into the circuit. The under dash lights even faded in and out like the dome light.
The high brightness standard should be very similar to if not brighter than the ccfl. The other handy thing about EL wire is that you can cut it to any length, whereas the ccfls come in set sizes.
#12 | |
It look's like I'm on the right track
Oh man, so nice, I just sent them an email. Hope they ship to Croatia :)
| 12 LED Dome Light Festoon | bigsky2 | Cosmetic Modifications (Exterior/Interior) | 26 | 04-18-2010 10:38 AM |
| aveo dome light trouble | TickleTimeTim | Off-topic / Other Cars / Everything else Discussions | 10 | 03-18-2009 01:08 AM |
| DIY:Day time running light Disabled with stock fog light remain function | summergxz | DIY / Maintenance / Service | 12 | 09-26-2007 10:42 AM |
| Festoon (dome light) led bulb fit?? | ||)) (o) ||\|| | Cosmetic Modifications (Exterior/Interior) | 5 | 03-22-2007 02:22 PM |
