Old 05-27-2009, 03:29 PM   #1
schleppy
I love momentum.
schleppy's Avatar
Drives: 2009 Yaris LB, Red
It's a good difference. The car turns a lot tighter and it feels like the rear end is finally oing something. The body roll can only be cured with better springs/shocks.
The only way you're going to end up with snap oversteer on the highway is if you're doing something absolutely ludicrous. Something so ludicrous that it probably would have happened without a sway bar.
Old 05-28-2009, 09:17 AM   #2
TheSilkySmooth
TheSilkySmooth's Avatar
Well, when you have an "Emergency avoidance maneuver" It will put the suspension to its limit. So I will know what its going to do in a fast lane change, I test it when there is less traffic by slalom-ing about a half lane out of my lane at about 70-75 MPH. With the stock setup with 15" bridgestones with 29psi in the rears, the rear will start to slide, wag or fish tail about a couple inches during this maneuver. I would imagine if I stiffened up the rear, this might become unmanageable and the car would have UNSAFE emergency lane change capabilities. - Anybody want to try and report back, or are you uncapable of advanced driving?
DIY - rear sway bar [pics] cali yaris DIY / Maintenance / Service 199 07-28-2022 05:25 AM
Ultra Racing 23mm Rear Stabilizer Bar Loren Performance Modifications 62 05-18-2009 07:20 PM
Does the TRD rear sway bar promote tire wear? detroiter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 03-29-2009 10:29 AM
TRD rear sway bar...street or race setting? detroiter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 14 02-08-2009 02:26 AM
TRD Rear Sway Bar Install ?? bikegerm Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 12-26-2008 01:46 AM
