Old 05-27-2009, 11:37 PM   #1
Kal-El
Kal-El's Avatar
I have 215/50/15's on my stock steelies. Very slight rub on full turn.
They certainly look better when the tire flairs out a bit from the wheel covers (rather than the covers protruding beyond the 185's). Looks less cheap.
My next set will probably be 205/60/15's as I want a little more sidewall to fill out the fenders a bit more. Unless I can get my rims soon (17's).
Old 05-28-2009, 05:47 PM   #2
SailDesign
Drives: .
I have 215/55/15's on my stock steelies. Very slight rub on full turn.
<snip>
My next set will probably be 215/65/15's as I want a little more sidewall to fill out the fenders a bit more. Unless I can get my rims soon (17's).
the 215/55-15s are about 1/2" bigger (taller) than stock - not a real problem. The 215/65-15s, though, will be more than 2" taller, and will make your speedo read very wrong (apart from other considerations that may play here). You will be reading 70mph when in fact you will be doing 76.5 mph. The cops are not likely to think oversized tires are an excuse...
If you are rubbing "a bit" now, you will definitely rub with the 65 series.
Old 05-28-2009, 11:34 PM   #3
Kal-El
Kal-El's Avatar
215 is width, not height. The 55 measurement is sidewall height.
So my 55's are lower than stock. If I were to go 215/65/15, they would be the same sidewall height as stock.
And as for the speedo, my smaller diameter didn't affect the speedo at all (I have a nav that reads the same exact speed).
Old 05-29-2009, 09:00 AM   #4
SailDesign
Drives: .
Ummmm - please read Kimona's link. The "55" is the sidewall height, true, but as a percentage of tire width. So the actual height of a 215/55 is 118.25mm. and the height of the sidewall on a 215/65 is 139.75mm. That makes the 65-series 43mm (twice the difference above) taller than the 55-series.
Small differences in height won't show up on an analogue speedo (can't read it accurately enough) but a 10% diffence sure will.
Bulb Replacement Guide (led Sizes) theFEVA Cosmetic Modifications (Exterior/Interior) 113 02-28-2017 12:02 PM
OEM Tire Replacement mm34b Wheels, Tires and Suspension Forum sponsored by The Tire Rack 9 03-10-2009 08:02 PM
TIRE Replacement buchieboy Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 02-04-2009 12:52 AM
Tire diameter list grampi Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 06-04-2007 04:03 AM
