Old 03-10-2009, 01:42 PM   #1
mm34b
Drives: Honda S2000
Send a message via ICQ to mm34b
OEM Tire Replacement
A friend of mine has a 2007 Toyota Yaris Sedan. The OEM tire size is 175/65x14 on a 5" width wheel.
My recommendation is to upgrade to 185/60x14 for a better selection of performance-oriented "all season" rubber. I'm thinking Bridgestone Potenza RE960AS Pole Position. Since I'm not that familiar with the Yaris, what do you guys think?
Thanks.
mm34b is offline   Reply With Quote
Old 03-10-2009, 02:38 PM   #2
kimona
kimona's Avatar
Drives: 2014 White VITZ
185/60/14's are too short.
Old 03-10-2009, 02:51 PM   #3
mm34b
Drives: Honda S2000
What size do you recommend, keeping in mind the narrow wheel width?
Old 03-10-2009, 03:02 PM   #4
silver_echo
ekodrvr
silver_echo's Avatar
if he wants a little better performance, i would recommend going up to a larger wheel... downside is that with a larger wheel, there will be more unsprung weight, and your gas mileage will take at least a small hit...
side note, after looking up on the tire sizes list compared with a tire sizing calculator, his best bet for a 14 inch wheel would be a 195/60/14
personally, i went up to a 17 inch wheel from OEM, with a 205/40/17 tire(mine is off by 0.65 MPH at 30 on my speedo), but did lose a couple MPG... car handles nice now... but there are options in between for both a 15(185/55/15, off by 0.07 @30) and a 16 inch wheel(205/45/16, off by 0.4 @ 30)...
silver_echo is offline   Reply With Quote
Old 03-10-2009, 03:16 PM   #5
kimona
kimona's Avatar
With a 5" wheel, you can run up to a 195mm tyre. Yes, some have installed 205's on the OEM steel wheels, but that's a bit tight... but doable.
This is from the Official Yaris Wheel and Tire guide: http://www.yarisworld.com/forums/showthread.php?t=5021
175/65/14 = 23.0
185/65/14 = 23.5
195/65/14 = 24.0
195/60/14 = 23.2
205/60/14 = 23.7
215/60/14 = 24.2
Old 03-10-2009, 06:27 PM   #6
mm34b
Drives: Honda S2000
Thanks.
My only concern is that I can't find a tire manufacturer that recommends installing a 195/60x14 tire on a 5" width wheel. The all seem to say 5.5"-7.0".
Old 03-10-2009, 07:04 PM   #7
silver_echo
ekodrvr
honestly i would recommend that he upsize at least one level to put the wider tires on
Old 03-10-2009, 07:45 PM   #8
kimona
kimona's Avatar
Originally Posted by mm34b View Post
Thanks.
Recommended wheel width for 205mm tyres is 5.5-7.0.
For 195mm tyres, recommended wheel width is 5.0-7.0.
Order your tyres on-line and save some money, then bring them to a garage (Walmart) for installation.
Here you go: http://www.discounttiredirect.com/di...w=false&cs=195
Old 03-10-2009, 07:47 PM   #9
14" tires are shorter than the cars that come w/ 15's
i run 185-60-14 fuzion hri's in summer and i love 'em....good treadwear, cheap to buy, and really good wet and dry traction
Old 03-10-2009, 08:02 PM   #10
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
why not source some 15" steelies used, they are cheap, and then you can run the bigger tire.
Edit: nvm, just saw silver_echo's post above
Why does Tirerack reccomend 185/50R15s for seeminlgy ALL of their 15" rims? St_G Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 03-16-2011 06:29 AM
O2 Sensor for 2000 Vitz - OEM replacement part? bahamasvitz DIY / Maintenance / Service 0 02-06-2009 11:12 PM
TIRE Replacement buchieboy Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 02-04-2009 12:52 AM
Tire diameter list grampi Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 06-04-2007 04:03 AM
