Old 05-29-2009, 09:16 AM   #1
YarisDude
Drives: Yaris Hatchback
Loren,
Great article. Wish I knew this procedure when I drove my CRX. I had a nagging pulsation due to the front rotors. Upon inspection there was an imprint of the pad on the rotor surface (as mentioned in the article). Not knowing the procedure discussed, I removed, resurfaced the rotors, and replaced the pads. Lots of unnecessary work. Well, I know the proper procedure to avoid that project! Like most things, knowledge can save time, money, and aggravation.
YarisDude is offline   Reply With Quote
Old 05-29-2009, 12:29 PM   #2
1stToyota
1stToyota's Avatar
Originally Posted by YarisDude View Post
Loren,
Wouldn't have helped the OP at all. As mentioned, dealer discovered that the rotor(s) had excessive runout, not rust stains, getting the brakes real "HOT" would have more than likely warped the already warped rotors even more...getting them real "HOT" within the first 10 miles by an idiot test-driver most likely warped the rotors in the first place. They were under warranty, would have been really silly to get them "HOT" when the problem was fixed for free at the dealership.
1997 Lincoln Town Car - SOLD
2008 Scion xD
(w/ automatic) - SOLD
2008 Yaris HB - SOLD
DIY (sorta) - RunStop Rear disc brake conversion eTiMaGo DIY / Maintenance / Service 17 07-02-2019 08:24 AM
DIY Rear Drum Brake Adjustment/Parking Brake W/ PICS Inside YarisSedan DIY / Maintenance / Service 73 03-11-2017 06:05 PM
Dealer: Disabling the seat belt chime is now illegal? schleppy Cosmetic Modifications (Exterior/Interior) 13 04-18-2009 04:43 PM
DIY For radios that require attaching a wire to parking brake Slick DIY / Maintenance / Service 0 04-16-2009 08:14 PM
BIG(GER)TM BRAKE KIT Vanderkitten Performance Modifications 23 01-04-2009 07:16 PM
