Old 05-29-2009, 09:16 AM   #13
YarisDude
Drives: Yaris Hatchback
Loren,
Great article. Wish I knew this procedure when I drove my CRX. I had a nagging pulsation due to the front rotors. Upon inspection there was an imprint of the pad on the rotor surface (as mentioned in the article). Not knowing the procedure discussed, I removed, resurfaced the rotors, and replaced the pads. Lots of unnecessary work. Well, I know the proper procedure to avoid that project! Like most things, knowledge can save time, money, and aggravation.
YarisDude is offline   Reply With Quote
DIY (sorta) - RunStop Rear disc brake conversion eTiMaGo DIY / Maintenance / Service 17 07-02-2019 08:24 AM
DIY Rear Drum Brake Adjustment/Parking Brake W/ PICS Inside YarisSedan DIY / Maintenance / Service 73 03-11-2017 06:05 PM
Dealer: Disabling the seat belt chime is now illegal? schleppy Cosmetic Modifications (Exterior/Interior) 13 04-18-2009 04:43 PM
DIY For radios that require attaching a wire to parking brake Slick DIY / Maintenance / Service 0 04-16-2009 08:14 PM
BIG(GER)TM BRAKE KIT Vanderkitten Performance Modifications 23 01-04-2009 07:16 PM
