Old 05-27-2009, 11:15 AM   #8
Loren
What?
Loren's Avatar
Drives: 2007 Yaris LB
Originally Posted by 1stToyota View Post
Not too likely that deposits and irregularities developed from pad wear within the first 10 miles on the vehicle like the OP stated, more likely rotors are warped due to abuse or improper lug torque.
Rust on the brake rotors from the car sitting on the lot. Simple as that. The area where the pad was didn't rust, so you have a difference in surface textures that you can feel.
Just do what I said, it will fix the problem.
DIY (sorta) - RunStop Rear disc brake conversion eTiMaGo DIY / Maintenance / Service 17 07-02-2019 08:24 AM
DIY Rear Drum Brake Adjustment/Parking Brake W/ PICS Inside YarisSedan DIY / Maintenance / Service 73 03-11-2017 06:05 PM
Dealer: Disabling the seat belt chime is now illegal? schleppy Cosmetic Modifications (Exterior/Interior) 13 04-18-2009 04:43 PM
DIY For radios that require attaching a wire to parking brake Slick DIY / Maintenance / Service 0 04-16-2009 08:14 PM
BIG(GER)TM BRAKE KIT Vanderkitten Performance Modifications 23 01-04-2009 07:16 PM
