Old 05-27-2009, 11:59 AM   #10
Loren
What?
Loren's Avatar
Drives: 2007 Yaris LB
Originally Posted by 1stToyota View Post
Just suppose that there was rust, using them once, or 100 times since the initial 10 miles should have cleaned off the rust buildup. Yes, just get the brakes real "HOT"...you'll have rotor and pads problems for sure.
Didn't read that article, did you? That's okay, it was only written by an automotive brake system engineer. Nobody you should trust, or anything.
If you understand how brakes actually work, then you'll understand why getting them hot is an important part of breaking them in. You'll also understand that anytime you allow rust to take over the surface of the brake rotor, you need to redo the break-in procedure.
DIY (sorta) - RunStop Rear disc brake conversion eTiMaGo DIY / Maintenance / Service 17 07-02-2019 08:24 AM
DIY Rear Drum Brake Adjustment/Parking Brake W/ PICS Inside YarisSedan DIY / Maintenance / Service 73 03-11-2017 06:05 PM
Dealer: Disabling the seat belt chime is now illegal? schleppy Cosmetic Modifications (Exterior/Interior) 13 04-18-2009 04:43 PM
DIY For radios that require attaching a wire to parking brake Slick DIY / Maintenance / Service 0 04-16-2009 08:14 PM
BIG(GER)TM BRAKE KIT Vanderkitten Performance Modifications 23 01-04-2009 07:16 PM
