#19 | |
#20 |
Very cool. I think that these are now on my list of things to do! Thanks for sharing...
#21 |
Did you notice any difference in handling or how the car drives. It is really annoying how the rear tires do not sit flush with the body like the front do. I cant wait to get mine.
#22 |
★weeaboo★
Not really no. Can't say that I have. Although it's only been a couple of days and I have yet to take it up to the twisties to have some fun.
![]() Worth it to not have the sunken-in look IMO. |
#23 |
I just installed my set, but the passenger side is rubbing (I guess I should've made sure I got 2 10mm sets before installation). Also, one of the screws on the driver side (lower-right) did not go through the hole, so I ended up using a shorter one instead. Is that OK?
#24 |
#25 | |
i'm trying to recall if i sent lock washers with your set or not. a lock washer should space the bolt out so it doesn't touch the axle. are you saying i sent you a 10 and a 13? please double check this, as my counts are still even in my inventory
#26 |
Hmmm mine didnt come with any washers. Should i be worried?
Also no penguin sticker too =( |
#27 |
no need to worry, washers are not required on 13mm sets, and are only sometimes needed on 10mm sets. and the penguin stickers JUST arrived today, didn't want to hold up spacer shipments for mere stickers
#28 | |||
The lower-right bolt on my passenger-side rear wheel went in fine, but it didn't go out, meaning that the hole at the other end wasn't large enough to fit the bolt. I ended up using an OEM bolt instead, which didn't go through by 3-4 threads, so I'm a bit worried it may snap. Quote:
#29 | |
TK, perhaps take the bolt i sent and have it cut off a little? i haven't run into this issue with any of the 4 cars i've done so far. and the washer is simply a 1/2" split lock washer, nothing fancy
#30 |
These bolts should basically be OEM length plus whatever spacer size you get (adding the additional stack height). I plan to be able to install these without issue when I get them....maybe penguin garage could come on here and talk about how they package their kits?
#31 |
![]() ![]() ![]() Drives: Yaris Join Date: May 2009
Each kit comes with:
2 spacers 8 bolts 1 packet of grease 8 lockwashers (10mm spacers) the bolts are of sufficient length to stack up to 26mm in width. |
#32 |
Hmmm my 10mm kit came with no lockwashers. Maybe i got sent the wrong kit and got a 13mm one instead?? I need to grab a tapemsure now
#33 |
note: Installed these this a.m. and everything was easy aside from getting the drum off. I don't know why I didn't try earlier but my steering wheel puller was the CORRECT and EASY way to remove the drum. Took 2 seconds and no hammer.
#34 | |
Sorry about that. EDIT: also sending out Penguin Stickers to all those who didn't get them yet. :) |
#35 |
I painted the hub spacers exposed portion with eastwood chassis black. I bet a Toyota tech wouldn't even recognize them.
![]() These make a nice subtle difference for sure....the car is one step closer to looking the way the it should have come from the factory.
#36 |
Beast
GIMMIE MY STICKERZ!!1111
![]() One you've taken a yaris for a spin, there's no turning back. Its a Chao!!! |
| Penguin Garage Rear Hub Spacers!! | Penguin Garage | Sponsors Classifieds Area | 92 | 09-02-2009 06:16 PM |
| Gauging interest on hub spacers for the yaris | Tamago | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 61 | 05-22-2009 02:18 PM |
| Rear Spacers... (Who sells them?) | Saggio | General Yaris / Vitz Discussion | 6 | 02-06-2009 08:40 AM |
| Installing a rear window defroster | trn9 | DIY / Maintenance / Service | 0 | 01-06-2009 02:56 AM |
