Old 05-29-2009, 09:05 PM   #11
Tamago
Tamago's Avatar
Drives: UZJ100
I just installed my set, but the passenger side is rubbing (I guess I should've made sure I got 2 10mm sets before installation). Also, one of the screws on the driver side (lower-right) did not go through the hole, so I ended up using a shorter one instead. Is that OK?
it didn't go through? meaning it was too long?
i'm trying to recall if i sent lock washers with your set or not. a lock washer should space the bolt out so it doesn't touch the axle.
are you saying i sent you a 10 and a 13? please double check this, as my counts are still even in my inventory
Penguin Garage Rear Hub Spacers!! Penguin Garage Sponsors Classifieds Area 92 09-02-2009 06:16 PM
Gauging interest on hub spacers for the yaris Tamago Wheels, Tires and Suspension Forum sponsored by The Tire Rack 61 05-22-2009 02:18 PM
Rear Spacers... (Who sells them?) Saggio General Yaris / Vitz Discussion 6 02-06-2009 08:40 AM
Installing a rear window defroster trn9 DIY / Maintenance / Service 0 01-06-2009 02:56 AM
