Originally Posted by DerFlosser
screw? Do you mean bolt...and are talking about the hub mounting bolt?
Yes
Originally Posted by Tamago
it didn't go through? meaning it was too long?
The lower-right bolt on my passenger-side rear wheel went in fine, but it didn't go out, meaning that the hole at the other end wasn't large enough to fit the bolt. I ended up using an OEM bolt instead, which didn't go through by 3-4 threads, so I'm a bit worried it may snap.
i'm trying to recall if i sent lock washers with your set or not. a lock washer should space the bolt out so it doesn't touch the axle.
Could I get a picture of those washers you mentioned?
are you saying i sent you a 10 and a 13? please double check this, as my counts are still even in my inventory
I am pretty sure I got it figured out now. I had a scrape removed from the passenger side fender a few days ago. Looks like the "ding doctor" ended up flattening the fender area a bit too much, making the tire rub with the fender. I may have to roll it back out a bit to fix that. So I'm 99.99% sure I did get 2 10mm spacers after all.
