![]() Drives: Toyota Yaris Join Date: Jun 2009
Change Engine Coolant
I want to chane the radiator coolant of my 2009 Toyota Yaris. I got under the car and look up. Behide the engine to the right I see a little bolt with a valse comes out. Is this where to let the coolant in the engine comming out ?
Thanks. |
There's a little white plastic wing nut looking thing on the
back of the Radiator at the bottom. |
If I may ask, why are you already changing the coolant in an 2009 Yaris?
2 drain points: Radiator and back side of block.
1stToyota:
Thanks for the reply. Where is it located on the back side of the block. If I just drain the radiator alone. Is it OK? |
Half a Bubble Off Plumb
You won't have completely drained and changed the coolant if you do that.
Why do you want to change the coolant on a new Yaris? |
If you just drain the radiator you are probably getting only half the coolant as the other half is still in the engine.
Also curious why the need for a coolant change when the coolant from new should last at least till 50,000 , most people never change it till the car starts overheating at about 180,000 and a new radiator is required. |
The one with cheese on it
Drives: '10 Corolla S Join Date: Oct 2008
Is it just me or is it odd that three members have asked the same question but the OP still hasn't answered it? Hmmm....
If it's just a drain and refill (w/ a 50/50 mixture) draining just the radiator is okay. But soon as you start flushing the system you won't be able to get enough straight coolant in the system with just a radiator drain. And the block drain is roughly in the middle of the block...crack open the bolt and fluid will come out of what looks like a little faucet.
![]() ![]() ![]() ![]() Drives: 2008 meteorite hatchback Join Date: Nov 2008
I agree - it's wayyy too soon to be changing your coolant. Unless you've thrown a turbo in your car running high boost and you want to put in better performing coolant, I'd just stay away from it until you need to get it taken care of.
- HOOOEY! That's one tahny little cawr! What the heck kinda toy is that? - A Toyota Yaris - A whut Yaris? |
Let's try again; why are you changing antifreeze on a brand new car?
![]() Might be a troll under the bridge boys.......
Coolant on our vehicles are designed for 100k for the first change and 50k every change afterwards. You need to make sure you purchase toyota only coolant as it is specifically designed for our cars and radiators. You also need to premix it with a 50/50 of distilled water.
Draining from the peakcock valve on the radiator will only get approx half of the coolant out of the motor as some is going to be left in the hoses and engine block. Proper way to be using a coolant flush machine that gets all the coolant out and puts all new coolant in. Something that any service shop can do. |
Just a FYI here. On my ECHO I used to change the coolant by using only the radiator drain. I measured the ammount that came out and it was what the book said was in there. Probably.....the Yaris is the same. In any event do not make a habit of letting others (especially the dealer!) work on your car. IQs have dropped sharply in the country in the paast few years. All they know is how the screw it up nowadays.
#15 | |
#16 | |
Or maybe the guys a busy fellow and just hasnt got back to his post.If he has a Yaris he'll be back.
^^^ And then there's the much dreaded cockblock that happens around the time a man gets married.
| DIY: Intake Installation | redyaris | DIY / Maintenance / Service | 53 | 08-23-2014 06:34 AM |
| Coolant level when engine cold | CB900F2 | DIY / Maintenance / Service | 4 | 04-05-2009 12:12 PM |
| Info regarding Engine change. | sheraz2000 | General Yaris / Vitz Discussion | 5 | 01-08-2009 01:51 AM |
| The Advantages of Nitrous on an Engine | KCALB SIRAY | Performance Modifications | 7 | 01-02-2009 11:53 AM |
| Engine Coolant Temperature | djino | General Yaris / Vitz Discussion | 18 | 07-16-2007 01:26 AM |
