Old 06-04-2009, 08:48 PM   #1
curtqn
Drives: Toyota Yaris
1stToyota:
Thanks for the reply. Where is it located on the back side of the block.
If I just drain the radiator alone. Is it OK?
curtqn is offline   Reply With Quote
Old 06-04-2009, 10:16 PM   #2
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
You won't have completely drained and changed the coolant if you do that.
Why do you want to change the coolant on a new Yaris?
Old 06-05-2009, 04:13 AM   #3
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
If you just drain the radiator you are probably getting only half the coolant as the other half is still in the engine.
Also curious why the need for a coolant change when the coolant from new should last at least till 50,000 , most people never change it till the car starts overheating at about 180,000 and a new radiator is required.
Old 06-05-2009, 08:41 AM   #4
1stToyota
1stToyota's Avatar
Originally Posted by curtqn View Post
1stToyota:
If it's just a drain and refill (w/ a 50/50 mixture) draining just the radiator is okay. But soon as you start flushing the system you won't be able to get enough straight coolant in the system with just a radiator drain. And the block drain is roughly in the middle of the block...crack open the bolt and fluid will come out of what looks like a little faucet.
1997 Lincoln Town Car - SOLD
2008 Scion xD
(w/ automatic) - SOLD
2008 Yaris HB - SOLD
DIY: Intake Installation redyaris DIY / Maintenance / Service 53 08-23-2014 05:34 AM
Coolant level when engine cold CB900F2 DIY / Maintenance / Service 4 04-05-2009 11:12 AM
Info regarding Engine change. sheraz2000 General Yaris / Vitz Discussion 5 01-08-2009 12:51 AM
The Advantages of Nitrous on an Engine KCALB SIRAY Performance Modifications 7 01-02-2009 10:53 AM
Engine Coolant Temperature djino General Yaris / Vitz Discussion 18 07-16-2007 12:26 AM
