#19 |
ahh, well you're good then!
#20 |
![]() ![]() ![]() Drives: 2007 Yaris Hatchback Join Date: Jul 2007
i didn't realize there was a difference (abs deactivated vs non-abs), but that makes sense seeing how abs needs to pump the brakes so rapidly
abs really gets in the way on smooth and dry surfaces, where it's not needed so much, but comes into play anyways.. on gravel and wet, it has it's ups ;D |
#21 |
Break'em off some.
Drives: 07 Yaris LB, 04 Cobra Join Date: Jan 2007
No real point in disabling it for the street though. It is no fun driving around on D shaped tires.
I locked the front wheels once in the Yaris (non ABS car) and flatspotted the front tires in a panic brake situation from 90 to about 30. It put a bad flat spot on the fronts. Luckily I needed new tires anyway. |
#22 | |
Break'em off some.
ABS cars are generally have more boos and are less linear to give lots of brake with minimal pedal travel, and the ABS will modulate if necessary. |
#23 | |
#24 |
Break'em off some.
#25 |
how many above average drivers are in this thread?
not me!
| rubbing up front under heavy breaking | regal | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 4 | 05-12-2009 12:23 PM |
| heavy braking | regal | General Yaris / Vitz Discussion | 8 | 05-12-2009 11:45 AM |
| ACT Clutch Kit 2007+ Toyota Yaris Heavy Duty 6 Puck | trini_per4mance | Items for Sale by private party | 0 | 12-20-2008 12:16 AM |
| A little Culture (heavy on the bandwidth) | GeneW | Off-topic / Other Cars / Everything else Discussions | 0 | 11-21-2008 04:50 AM |
| How Heavy is the flywheel? | jouslee | DIY / Maintenance / Service | 12 | 02-22-2007 02:18 PM |
