Old 06-09-2009, 11:01 PM   #1
EasyDriver
Drives: 2008 Yaris Meteorite LB
Tire Size...
I was just looking at http://www.miata.net/garage/tirecalc.html today investigating what tire I would get to replace my 185/60/15s. Mileage is my primary concern since yet again gas prices have risen to $2.95 here in lower Michigan. Every tire I have had in the older 70 & 60 series has worn poorly. If I was picking a 15" tire for my Yaris today I would get a Goodyear Fuel Max 195/65/15....more tire height, less revolutions per mile=more mpg. Not a lot maybe...but 2% or close to it. It seems like the majority of Yarisworld prefers the cooler looking wider series tires. Perhaps our Hypermiler members could shed some light on this.http://yarisworld.com/forums/images/smilies/biggrin.gif
EasyDriver is offline   Reply With Quote
Old 06-10-2009, 12:02 AM   #2
supmet
Drives: 2007 4 Door Yaris
Going from 185 to 195 will decrease your mileage more than going from 60 to 65 will increase it. You might still end up with an overall increase in mpg using fuel max tires though.
Old 06-10-2009, 08:40 AM   #3
scape
scape's Avatar
Drives: 2007 Yaris Hatchback
if your looking for mpg, and mpg only; a skinnier tire is more important, not a wider one. less rubber, less friction. and a taller tire does exhibit less rotations--but in town driving may suffer from you trying to overcompensate and is generally not a huge factor unless highway is your mainly your thing.
the standard prius has (to my knowledge) 185/65/15. i'd shoot for that if fuel was your concern-- someone on a forum mentioned goodyear integrity's as a good tire for this application, i'll see if i can find a link
just remember, you'll be travelling faster than your speedo reads (@ 60mph = ~62mph)
Bulb Replacement Guide (led Sizes) theFEVA Cosmetic Modifications (Exterior/Interior) 113 02-28-2017 12:02 PM
OEM Tire Replacement mm34b Wheels, Tires and Suspension Forum sponsored by The Tire Rack 9 03-10-2009 08:02 PM
TIRE Replacement buchieboy Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 02-04-2009 12:52 AM
Tire diameter list grampi Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 06-04-2007 04:03 AM
The Tire inflation debate... Tankota General Yaris / Vitz Discussion 20 06-01-2006 07:09 PM
