#37 |
![]() ![]() ![]() Drives: Yaris Join Date: May 2009
#38 |
Nice diy
#39 |
DARK PHASE OF THE MOON
Drives: 07 liftback Join Date: Apr 2009
Special Torque setting? As in do I need a torque wrench to do this simple procedure correctly?
#40 |
if you want to torque the bolts, you'll need a torque wrench. however, "tight" isn't very hard to achieve :)
#41 |
Got mine a week ago. Put them on today and I'm digging the new look
Sorry for not taking before and after shots, but that's just how I roll. Hardcore, no pics.Anyhow, the install was a breeze though I suggest when pulling the drum that you use those two screw holes provided. I tried prying it off a couple of different ways but didn't want to damage the back plate or anything else for that matter so the bolt in the hole did the trick. I just happened to have a small bolt that was perfect for it though I don't know the thread size. Just torqued on one hole til it started to pop off then did the opposite side. Piece of cake. Easy mod for a beefier looking back end. Haven't taken it through any turns to see if it makes a huge difference in handling, but given that the change is very noticable to the eye I would expect some extra stability out of it. I highly recommend this mod. Thanks Penguin Garage and Tamago! |
#42 | |
toyota
size of that bolt would definetely come in handy...i do use bolt to pry out the rotor as well if its stuck on the hub. makes is alot easier..and thats what those 2 or 3 small holes are for.
#43 |
Shut your fricken suck!!!
Where on the drum are you tapping with the hammer? Are you using a screwdriver as well to help pry it off?
#44 | |
I apologize that i have not yet posted the bolt spec for pushing the drum off of the hub. my guess is that it's a standard metric bolt (coarse thread) that has a 10mm thread. 8MM possibly? i'll definitely let you guys know my findings, i'll be doing new rear brake shoes soon.
#45 | |
Finally figured it out. It looks dope!
#46 |
edited. i added the ABS plug removal bit, stolen from the factory svc manual.
#47 |
![]() ![]() ![]() ![]() ![]() Drives: car Join Date: Oct 2008
Alright just got the spacers in. My kit didn't come with a penguin either but I did have camber shims and lube.
I'm worried about my brakes though because they're not as responsive as before. I noticed a big difference after putting in the spacers and braking. It's somehow related to the brake lines because they had to be stretched a little bit to reach the hub after it was spaced further from the car. |
#48 | |
#49 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 07 Yaris 3dr LB (Bayou Blue) Join Date: Oct 2008
I hate to say this but maybe a re-think on the sticker design is in order.... my penguin's beak got ripped off today after carefully sticking and re-sticking everytime I wash my car...... poor thing is this blobb animal now.... :(
-Jen <3 ![]() Quote:
#50 | ||
Tapping of the drum isnt really nessacary.... luckily the drum has two screw holes that take care of popping off the drum.... I thought I posted this already?
#51 | |
what color do you want? |
#52 | |
Shoot me a PM I'll get one sent out to you. |
#53 |
what is the hub spacer for anyways? ikno ima noob
#54 |
| Penguin Garage Rear Hub Spacers!! | Penguin Garage | Sponsors Classifieds Area | 92 | 09-02-2009 06:16 PM |
| Gauging interest on hub spacers for the yaris | Tamago | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 61 | 05-22-2009 02:18 PM |
| Rear Spacers... (Who sells them?) | Saggio | General Yaris / Vitz Discussion | 6 | 02-06-2009 08:40 AM |
| Installing a rear window defroster | trn9 | DIY / Maintenance / Service | 0 | 01-06-2009 02:56 AM |
