Old 06-13-2009, 07:06 PM   #11
Tamago
Tamago's Avatar
Drives: UZJ100
Originally Posted by marlondog View Post
Where on the drum are you tapping with the hammer? Are you using a screwdriver as well to help pry it off?
i've never had this issue, as i remove my drums every time i remove my rear wheels (simply to keep the corrosion factor to a minimum) however there is a small slot between the drum and the backing plate. you should be able to stick the corner of a block of wood (or a brass/copper punch) in this groove and go to town.
I apologize that i have not yet posted the bolt spec for pushing the drum off of the hub. my guess is that it's a standard metric bolt (coarse thread) that has a 10mm thread. 8MM possibly? i'll definitely let you guys know my findings, i'll be doing new rear brake shoes soon.
Penguin Garage Rear Hub Spacers!! Penguin Garage Sponsors Classifieds Area 92 09-02-2009 06:16 PM
Gauging interest on hub spacers for the yaris Tamago Wheels, Tires and Suspension Forum sponsored by The Tire Rack 61 05-22-2009 02:18 PM
Rear Spacers... (Who sells them?) Saggio General Yaris / Vitz Discussion 6 02-06-2009 08:40 AM
Installing a rear window defroster trn9 DIY / Maintenance / Service 0 01-06-2009 02:56 AM
