Old 06-16-2009, 12:43 PM   #1
Black Yaris
der Zeck
Black Yaris's Avatar
rear alignment shims for the Yaris can be found at Napa for $30 each
you just have to pay the going rate for an alignment
Old 06-16-2009, 12:48 PM   #2
Tamago
Tamago's Avatar
Drives: UZJ100
unfortunately they're plastic.
i use 1/2" stainless steel flat washers (about .060" thick) under the lower bolts. install then drive to the alignment rack, and then torque to achieve desired camber/toe.
stainless washers can be had at Ace hardware. i buy mine 25 at a time from Fastenal.
you will have to grind one edge of the washer flat so that it clears the hub.
if interested, i will sell anyone here 4 stainless washers (two each side) that are already ground and ready to install for $8 shipped in the continental US.
Hyperco 5.5" single pigtail rear spring test kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 33 06-15-2009 10:11 AM
Ultra Racing 23mm Rear Stabilizer Bar Loren Performance Modifications 62 05-18-2009 07:20 PM
