#1 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 07 Yaris 3dr LB (Bayou Blue) Join Date: Oct 2008
thnks!
can you install the bar with the car on the ground or does it have to be jacked up to do it?
-Jen <3 ![]() Quote:
Doesn't need to be jacked up, but you will need to support the shock/shock mount just a bit so you can get the bolt through once you remove the one that's there. I used the Yaris' hydro jack to push the shock up just a bit but there are other ways to do it.
Thanks for all the feedback. I think I'd like to stick to the TRD swaybar, but thank you for the offers. I figured you could install it while the car is on the ground, I did the install with my old '85 Grand Prix (solid axle with arms) in the driveway.
A must have mod.
$151.20 + tax vs. $134.95 to your door, no tax
DARK PHASE OF THE MOON
Drives: 07 liftback Join Date: Apr 2009
#1 upgrade for the $$
![]() ![]() ![]() ![]() ![]() Drives: Scion FRS RS2, ‘21 Crosstrek Join Date: Oct 2008
Every Yaris should have a rear anti-sway bar. It should be the law. Improved driveability, safety and fun-factor all with no down-side.
TRD Upgrades: 18" Wheels wrapped in 215/35/18 PZero's, Sportivo Shocks/Struts, Lowering Springs, Swaybar, Axle-Back Exhaust, Oil Cap, Rad Cap, Signage. Aftermarket Goodies: Piggies SS, K&N Drop-In, Blitz S/C, DC Header, NST Pulley) Toyota Options/Accessories: Sport Pedal Covers, Sport Shift Knob, Ipod Interface, Summer Mats, Winter Mats, Cruise Control, Auto-Dim Mirror, Echo steelies with winter boots.
"yes"
Okay, I bought the TRD bar from my local dealer, and installed it in my driveway in about 20 minutes. The mounting points are viewable if you look under the rear bumper. A few pointers: First, it's best if you park on a level surface. Then, do not remove the lower shock mount bolts all the way, leave them in with a couple threads of the end sticking out of the lower shock mount. This way you can mock the bar into position and when you get the mounting holes lined up, shove the lower shock bolt home through the hole, and start the nut. Repeat on the opposite side. Once you get the bar hung by the shock bolts on both sides, you can rotate the bar up and slip the bolts through the secondary mounting points. Torque it all down, take it for a ride and you are done!
Like I said, I did it all on the ground in my driveway. The difference in handling was immediately recognizable and this was definitely a worthwhile upgrade. Confidence in sharp, corrective maneuvers is increased, and going around curves is now something quite fun. As others have said, the Yaris should have come this way from the factory. Next step for me is to pump up the air pressure on the tires, this should increase some fuel mileage and stiffen up the ride a bit, too. Scott |
![]() ![]() ![]() Drives: 2007 Yaris Hatchback Join Date: Jul 2007
not to thread jack, but i'm wondering which I should get-- 19mm or 23mm. i don't plan on getting any wider of tires (195/55 series on 15) and am thinking 23mm might end up as too much
#12 | |
Scott Last edited by YellowJolt; 07-13-2009 at 11:18 AM. |
| Ultra Racing 23mm Rear Stabilizer Bar | Loren | Performance Modifications | 62 | 05-18-2009 07:20 PM |
| Does the TRD rear sway bar promote tire wear? | detroiter | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 3 | 03-29-2009 10:29 AM |
| TRD rear sway bar...street or race setting? | detroiter | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 14 | 02-08-2009 02:26 AM |
| TRD Rear Sway Bar Install ?? | bikegerm | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 6 | 12-26-2008 01:46 AM |
| solid torsion bar bushings... the best rear anti roll upgrade | turboyaris | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 28 | 12-05-2008 11:37 PM |
